They were pre 80.
I did loose a good one crossing a creek on a rope. Now if it doesn't ride in a secure sheath it gets a dummy cord(lanyard)!
Never heard of that but wouldn't be surprised to hear about breakage after the company started to tank.
As for wire saws, they suffer the twin fate of hollow handled knives. A lot of people bought shitty ones in the 1980s, wire saws and hollow handle knives and hollow handle knives with shitty wire saws included and now they hate both things and then the rest of the herd parrot them.
One of the really bad things about wire saws is the advertising - going back to the 1980s and continuing with BCB's advertising today, showing the wire saw being bent and sawing through a limb. In the vast majority of cases, it is going to break. The bend combined with the heat is going to break it.
I did the same thing in the 1980s! I was a dumbass!
The only difference is, I learned, some people do not and they then go on to condemn something that could be a very valuable tool if they would just stop thinking that they can treat every tool like it's a sledgehammer or a 36" wrecking bar.
These "BestWay" wire saws have been packaged two ways in the military's national stock inventory that I know of. You will see some of them in Tracon Survival Fishing Kits and that will be the slightly thicker fishing tin and the other way is in the yellow padded envelope you see on the link Jeff provided. The first USMC R-PIE SK I bought years ago had the yellow envelope with the saw in it. This time around, it had the thicker Tracon Survival Fishing Kit Tin and the saw...two blades and two handles, were in the fishing kit. This saved some space in the overall size of the SKIT as well.
On that yellow envelope is a clear illustration to use the saw as a bow saw by using a freshly cut green limb. Doing this with ALL wire saws will give you much better performance, the saw won't take a "set" from being bent and if you go slow and methodical, you will really have a great tool that can do a lot of things. If you just want to try to buzz through something like a meth-monkey, don't complain when something won't perform.
Now, the interesting thing about that website Jeff provided is the fact that they have Coping Saw and Hacksaw blades that are the same type of blade but much more robust! Coping Saw frames are
light and a Hacksaw frame would not be something that would be worth carrying if you had some of these very aggressive saw blades and a few flat blades as well.
Or, you could take the replacement blades for the Hacksaw and cut yourself a green limb and notch it, then put paracord or whatever type would fit through the eyelets and still be tough enough, place the knotted cord through the slots you cut in the branch and you would really have something that could go through a lot of different materials.
