Bob Dozier said:
I don't know any makers that grind as thin as we do and guarantee their knives againest being broke by heavy hammering.
I have a few puukkos which are more acute at the edge and ground out of thinner stock and will respond fine to baton work. A 1/16" carbon steel blade with a high flat grind is near impossible to break batoning, with that size of knife anyway, see Jim Aston's work for example. The biggest risk is turning the edge on a pin knot and they are typically very thin 0.010"-0.020".
[very hard hunting knives]
knifetester said:
Do any of them exhibit the extreme edge holding that Dozier knives are known for? Are they ground as thin? Do they cut as well?
Alvin's knives 1/4" back from the edge are thinner than the K2 at the edge, Phil's are thinner at the edge, Sorg's are of thinner stock and thinner at the edge. Phil runs harder and higher alloy steels (S90V, 10V, 15V) , Sorg used to run D2 at 62 HRC, Alvin usually runs 1095 and M2 full hard.
Wilson doesn't like D2 at 62 HRC either, he found it chipped too readily for him, he was really surprised by the behavior of the Sorg custom I have, I keep meaning to send it to him. He does however run others steels significantly harder.
Alvin doesn't like D2 as a blade steel at all, it can't take his edge profile. I like it in that profile but I use knives differently than him and run a different sharpness, specifially the Sorg slices forever with a 100 grit AO finish, but it much more coarse than Alvin like his edges.
Are the blades as optimally suited for cleaning game as Dozier's various offerings?
Lots of people use the them for such work, Alvin's are used by commercial meat cutters, Phil sells a lot to hunters (he is more fishing/hunting than utility), and that was a large section of Mel's market.
I can carve hickory all day long with the above blades without chipping them, and pop cans are no problem for most unless I have altered the profile drastically. I have been doing some bone carving lately, making pins and similar. You can cut a lot of hard materials with hard edges, just avoid impacts and no torques.
With the ZDP Calypso Jr. (~65 HRC) I easily cut a coke can into strips, no damage to the edge, still shaved. Chipped out on a can of mushrooms, but the edge was really acute ~10 degrees. I'll try it again with a micro bevel once I carry it for awhile and wear the edge back a bit.
With just woods, I go way down, ~5 degrees per side or so, maybe ironwoods would be a problem, nothing else seems to be though (hickory, birch, oak). I don't know if that profile could cut pop cans or not, I'll try it later on before I reset some edges.
Bob Dozier said:
It matters not what other maker harden their knives to...
Well to a user it does obviously, as a maker well I talk to makers about other knives all the time, they are usually very interested in what other people are doing with steels and grinds. There is always the possiblity you could learn, and in any case more information is always of benefit as you see where you stand.
-Cliff
