I have to say I would like a wheel that would fit a 72 inch belt, with just enough slack to go around a drive wheel and a tension wheel, but be as big as possible. Or a selection of 6 foot diameter stone wheels in 60 80 120 220 400 600 800 1200 2000 4000 8000 10000, that would just about do it.
Im going to be making a contact wheel at work. So im thinking something large.
Funny that you mention that Stacy, I was talking with a fellow that in his best attempt to re-create the same grinds used by the cutler's guild in Sheffield england had a machine shop machine him a platen with a 72" diameter curve which he then mounted instead of his flat platen so that the belt was pulled tight around the curve. I guess that would be one way to do it without having a 6 foot diameter wheel to lay into.
A friend of mine in Anchorage had a Burr Buster grinder with an 18" wheel, talk about shallow hollow grinds. My 14" wheel on my Bader does a good job for grinding shallow HG's.
you could do a 20" wheel and stick it on the motors shaft. then all you would need is a tracking/tension wheel. then use a vfd to control speed. full speed on a 1750 rpm motor with a 20" would be 9159 SFPM.
