Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
The interior will have three "rooms".
The "Clean Room" will be 20X12 and it will be insulated and have a mini-split HVAC unit. It will be drywalled and have a nice ceiling. It will be the fancy room.
The "Grinding Room" will be 10X12 and have plywood 48" high half-walls with glass above them. It will have a glass door to enter through. It has its own dust recovery and spark trap system as well as fan powered incoming fresh air. It will be pretty well sealed off from the rest of the hot shop.
The "Hot Shop" will be the rest of the area (the middle of the shop). It has a separate dust vac system from the grinding room along the benches and an overhead hood over the forge area. It has fan powered incoming air.
The grinding room and hot shop will have stainless steel benches with cabinets going down the wall above the benches. Between the benches and the cabinets will be covered with sound deadening and fireproof aluminum sandwich sheeting. Above the cabinets I will put drywall.
The walls in the rest of the hot work area will be covered with cabinets and such. I will drywall or panel any exposed places.
The hot work rooms ceilings will be open rafters as part of the ventilation system. I am likely to use that real estate to hang and display lots of cool stuff.
In the eves there is a big powered fan to draw hot air out of the shop.
