Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
- Feb 13, 2007
Long shot question of the day: anybody got advice for drilling 110V? It is very difficult to drill without the material work hardening very hard. I think this stuff comes in the door in the low mid 40s rc.
I have the best luck with carbide but it is very easy to ding them up.
I haven't drilled 110V but I drilled a lot of M4 last year using a regular HSS drill.
These are expensive parts I'm making and I'm using very conservative numbers with no regard to cycle time. I'm using an American made HSS 1/8" drill and drilling 1/2" deep in two places. 3.0 IPM and 1070 RPM and pecking every .100". I cut 40" of CPM M4 with one drill before changing it. And I'm certain it could go much longer than that but the material cost dictates I change cutters frequently.
I'm sure 110V is worse than M4, but M4 is no cake walk. I'm pretty sure your problem is under feeding, which was the purpose of this thread. If you're not pushing it hard enough to break your chip you're not pushing it hard enough. You should not be getting birds nests or chatter. Keep that cutter feeding or you'll work harden your steel. Once your cutter is dull through it away. I expect I would get at least 10" out of a drill in 110V before dulling it.
This is an application for a cobalt 135 deg split point.
Harder material requires more force to get the web to penetrate fast enough to maintain a proper chip. If you're not flowing metal over that cutting edge it is sitting there rubbing (lots of carbides in 110V) and hardening your work piece. Lean into it (within reason) and lift as soon as the web penetrates and regular HSS should cut that just fine.
