- Oct 20, 2008
This is a simple little 4" drop point hunter with a rabbeted tang and curly koa handle. Blade steel is CPMS30V. I built it at Ken's shop, and definitely learned some good things with it.
I drew a pattern on a piece of paper, photocopied it, kept a copy, then cut the drawing out of the paper. I took some 3/16" white plexiglass from a sign shop, spray glued the paper pattern on, and used a bandsaw and belt grinder to profile the plastic right to the outlines of the drawing. Here is the pattern:
I included what pics I could but the blade appears already rough ground and heat treated in these pictures. I got carried away and did a good bit of work before I remembered I had the camera and was going to do a WIP! More pics next knife, I promise... The pattern has a couple possible configurations of pins/rivets drawn onto it, eventually I settled on a single Corby.
Nothing too special, flat ground on a Burr King and disc grinder, 36 grit gold belt first, then 220 and 400 grit J-flex belts. I trued the flats on the disc, then hit it lightly with a fine scotch brite wheel before stoning with #400, then #600 Falcon slip stones. I then wet sanded it at 600 grit.
[/IMG]
Actually, this was all done after heat treat. The blade was only profiled before HT, I never tried that before but Ken recommended trying it to minimize warpage. Surprisingly, grinding was not too bad afterwards, although stoning and sanding took some elbow grease for sure.
This is the blade at 600 grit, with some sanding left to do.
[/IMG]
I'll try to post again tomorrow, thanks for looking.
