- Sep 23, 2014
No, I'm not jumping back and forth. I'm finding an angle and a stone surface and stick to it for an hour at a time.
The other day, one hour straight on coarse diamond, then an hour on fine side.... at 25 degrees, then ripped paper with my knife.
I'm not doing 25 degrees for 8 strokes then 10 strokes at 35 etc... I pick and stick to one thing.
Well, next time, do this instead
Do 20 degrees, coarse stone only, grind one side for a full minute, scrubbing passes, then check for burr,
don't switch sides until you raise a giant floppy burr you can see from space
this is the fallback technique when you just can't seem to get something sharp,
grind one side until giant burr
then switch sides and grind other side for one minute at 20 degrees, coarse stone only, scrubbing passes, and check for burr
when you raise a burr on the other side, move onto fine stone,
double the angle to 40 degrees
and do maximum two passes per side alternating with light force to cut off the burr
feel for burr again, and do two more alternating passes if you need to
you should be shaving sharp now
you can now do 5-10 alternating passes at 20 degrees or 25 degrees,
but do no more than 30 passes per side
You can see this guy do it on a smith's coarse bench diamond stone, although he uses too much force and wears out the stones how to sharpen a knife - Joe Calton
update:
you should keep force on diamonds under 1lb (450grams) or about half pound (225 grams)
for cutting off the burr keep it under 100 grams
