- Mar 4, 2014
I've had my Maratac for a month and have used it a dozen times. Just did a refill to see how much fluid it needed and it was only a few drops to top it off.
Seems to last longer than BF's peanut??
The single O-ring seals it well.
Yeah, my Peanut probably lasts longer. But depends on how long you let it burn. Most of the time mines been lit, is from showing it to others when conversations drift to edc things.
I tried all the tricks to keep zippo's from evaporating. Nothing worked, and was always dry when needed. So now I just scatter bics and ronson's around the house and car. If I have a choice, I much prefer the ronson butane lighters. The fine tip of flame allows you to be more specific for point of contact. Whether I'm lighting up a birthday cake, or melting the end leather stitching waxed thread. Or even melting paracord ends. They are cheap and easy to refill.
Ronson Jetlite Butane Torch Lighter - Satin Dusk Embossed https://www.amazon.com/dp/B007D50SSE/ref=cm_sw_r_cp_api_FcnLybCQ944E9
And now that I have a bunch of the butane's scattered around, I will probably get more of the electronics. They do not take the place of a flame when you need instant fire and heat (like for my leatherwork hobby). But if you just need something lit up, they are just so cool. [emoji41]
USB Lighter - SPPARX Arc Lighter, Dual Arc Electronic Lighter - FASTER - STRONGER - SAFER - Rechargeable Lighter Windproof, Cigarette Lighter, USB cable, Gift Box https://www.amazon.com/dp/B01DICHC2K/ref=cm_sw_r_cp_api_MpnLyb2XHM6JS
Sent from my mind....using Tap-a-Thought. (tm)
