sharp image
Platinum Member
- Oct 28, 2024
Don't encourage him.I think we need audio.
Hi Ferider, which brand and model is that fixed blade? Looks great.Morning.
Looks like a fiddleback forge knife.Hi Ferider, which brand and model is that fixed blade? Looks great.
Production Duke I thinkLooks like a fiddleback forge knife.
It’s a Fiddleback Forge (Production) Camp Knife in 3V and Micarta. Thx !Hi Ferider, which brand and model is that fixed blade? Looks great.
That's very interesting, thanks for explaining. I remember you've said what those things are for before once or twice since I've been back to Bladeforums, but I always forget after a while and wonder what they are every time you post oneThis particular sub assembly is fairly simple in comparison to the rest of the equipment and is solely mechanical in nature but is just as important as the rest. There are only a handful of parts but all are subjected to a harsh environment operating a few miles under ground (drilling an oil/gas well) with up to 1000 gallons per minute of abrasive mud, filled with additive chemicals flowing through and around these parts with high pressures and high temperatures (relative to the design and materials etc) so the potential to erode away everything quickly is a concern if not setup correctly. everything is scrutinized bc you don't want to be the reason the rig had to stop drilling for days which is expensive.
For this particular piece of equipment, the rubber seals on the piston in that bore need to survive long enough in the environment to get that section of the job done, say 100 hours at a time, before needing rebuilt and parts replaced, so the seal’s extrusion gaps have to be as tight as .003” diametrically or .0015” on each side in between the bore wall and piston OD. Nothing too crazy but too tight and it will bind up and too loose it will fail within hours in a multitude of ways and it will only get looser as it runs so all parts are machined and finished with only a few thou for min/max tolerances and have to be measured at several steps in the assembly process while taking into account any potential tolerance stacking to insure those spaces between the bore ID and piston OD, where those seals will live, fall within the tolerances that have been honed in over time/ experience to work. Idk how interesting that is but a pic is worth a thousand words I suppose and yes Everything in the Oil industry is definitely expensive!
Stretch 2 XL again today
