- Oct 3, 2002
Like Nathan said, edge too thick. I go back to the grinder after HT and take the edge down to .010" or so, then start hand sanding.
For most applications, .032" might be a little too thick to apply your edge. Such a thick edge won't cut very well. Try .015-.020.
.010" if you're feeling daring.
10-15 deg per side.
So I should grind it down until the edge is about .015"- .02" wide, then sharpen it at a 20-30 degree included angle? Is that correct? Thanks!!
All I can say is send them to ROb at Ranger Original and your problem will be solved. My neibour has skinned and gutted 1 elk ,2 deer and never sharpend the cpm 154 skinner I made him , as a matter of fact he said it still shaves the hair on his arm .
Are you taking off the decarb layer from heat treat? even with a foil envelope you will likely have a few thousandths of decarb. Also a 40 degree included angle is a cold chisel not a knife.
-Page
Machinest, first off I am replying to the person who started this thread SINAWALLI . Now as far as I can read he is in alberta canada just down the road from a great guy that heat treats for a living. SINAWALLI also said he is a AMATURE. So I guess if He send his steel out to someone they are screwing it up some how.Even a chisel edge should stay sharp with a #1 steel like cpm154
What instrument or tool do you guys use for measuring the edge thickness? Whatever it is, I need to get one.
I use a dial vernier.
Thanks!I have a caliper but it is kind of a cheapo unit. Perhaps I'll get me a nice digital one.
Personally, I don't like the digital ones, I prefer a dial. Just don't buy a cheapy, spend the $$ and get a Mititoyu or Starrett. If you buy a digital, get a waterproof one!
I read all the the threads and see that Rob did your heat treat . This is how i finish my edge. I get it back from rob after ive sanded to 500 sometimes even 1200.grit structured abrasive belt I leave the edge very thin and sometime by accident sharpened the edge letting rob know so he doest cut himself. I take my sanding back to 500 take off the carb and go to 3000 then go to the paper wheel after the handle is all done . The paper wheel is one awesome device for sharpening. Your angles mean alot and if you over heated you blade while finishing you ruined the heat treat. I do my skinning knives at 18 to 20 degree s and kitchen and fillet at 15 degrees.
