Anne,
I guess I didn't directly address the edge holding very well.
For field work I use a Spyderco two-sided hone (white and dark brown). It flattens the edge somewhat and makes it look kind of fugly but works.
When out of the field I straighten up the edge with a large hone. You don't need to get a specific hone and test to see what will give a good edge like a lot of knives, anything I've used to (include emery paper on a hard surface) will give a good edge. Then using something with a little give (hard rubber, etc.) lay a piece of 600-800 grit emery paper an strop away from the edge to get you the small radius back. Follow with finer paper if available or a loaded strop.
The edge doesn't seem to loose it's edge as fast as a certain "high end carbon" steel from corrosion. I know it's not listed as a stainless but it does resist somewhat.
I haven't had any edge damage but choose the I to get the spearpoint. Old trick is to use spear top edge top down for chopping stainless comm wire, metal banding straps, etc, to save the primary edge.
I'll also disagree with the review posted on the utility for food preperation. I try knives in the kitchen for carving and other tasks. It worked just fine for carving turkey, beer butt chicken, ribs to name a few. I haven't tried it on fish as I'm not much of a fisherman. It is a little big for squirrel but usable on rabbit, pheasant, deer, and antelope. Obviously not it won't perform as well as a well executed knife designed for the respective tasks but there is a limit to what one can carry.
S/F, Mike
