stress factors are actually are increadible at the edge since a very small amount of metal is actually pushing on the material that is cut. i've heard that in any single alloy that 2 points increase in rockwell increases the edge durability by 20%. simply said if you increase the rockwell of 1095 by 2 points , the durability of edge increases by 20%
dennis
Nice write-up. Have you noticed one edge cutting noticably better than another, with the wear appearing equal? It logically follows that increased wear will increase the force required to cut, but there could be exceptions - like the theory that D2 keeps cutting longer because of the way it wears (big jagged carbides being worn off leaving other big jagged good cutting carbides). Might require testing with duller edges to have a chance of observing this.
With hardness the best indicator of edge retention, and hardness being related to ultimate tensile strength, then it follows that edge retention is dependent on strength. This points to the major factor to dulling being the strength of the steel at the edge being exceeded by the pressure required to fracture the material being cut. This is obvious, but is still worth stating to emphasize the immense pressures of cutting & the role strength plays.
A very nice job--matching geometries is the ONLY way to generate any kind of meaningful comparisons between alloys/heat treatments.
One thing I'm curious about---where on the knives did you do the cutting? If you were, for instance, to do this test with that Queen Stockman with the straight part of the blade, and then again with the belly out front, I think you would find that the curved section's slicing edge retention is superior to that of the flat section's, as the curve gets a more progressive move into the cutting medium and so has less pressure on it--which in turn means less stress/damage. Think of a hinged paper cutter versus a gillotine.
I'm not saying the differences would be huge, but the variances in curvature between the blades do have some effect on their shearing characteristics...although you might have already thought of that.
Ideally, not only the grind angles but also the actual blade shapes would be identical. Alas, those goofy manufacturers all have their own ideas about what shape the blades should be.
Anyway, this isn't a quibble, just an observation. Still a very streamlined, controlled process, and one of the EXTREME few that I think actually deserves to have the name "test." Many will post comparisons/conclusions based on "data" that's so ridiculously skewed that I sometimes wonder if they're kidding.
It makes me wonder why more makers dont use D2.
Makers that like putting a high polish on their blades will at times steer away from D2 ( and S30V) due to the steel being notoriously difficult and time consuming to finish to high grit levels. D2 even has a kind of orange peel effect even when mirror polished.
Like any other vocations people have preferences and dislikes.
I don't agree with this but how many times have we heard that "D2 takes a lousy edge and holds it forever".
Though not my favorite steel I do like D2, and CPM D2 but if I had to put out a certain amount of knives per month to survive I'd be looking at steels like AEBL, ATS 34, 154cm, and CPM 154, and in carbon /alloy steels I'd be pushing 5160, 1084, 1095, etc.
Steels like 10V, S110V, S90V, would be rare, special order only with prices to match the extra time, abrasives, higher temps etc. One could probably make 1.5 to 2 -12C27 knives for every knife made out of S110V.
I would love to see tests on, say, 9 identical knives that vary 1 pt. in HRC. Like 9 or 10 Spyderco mules in one steel ranging from 55 to 65 HRC. That would be very, very interesting.
Do you think that the recurve on the 710 could have contributed to the better push-cutting ability?
No sir, I do not.
I used a section that was pretty straight for the cutting. I think it was the difference in hardness.
To be truthful I think I need to take the D2 off my chart, but for a different reason. Most of the others alloys are 59±1 HRC. To compare those to something over 61 isn't a square comparison. But what's a mutha to do? D2 works optimally at a higher hardness than the other alloys. Rats!
The issue is one that bothers me. One the prerequisites for my comparisons was that I would test the alloys all at the same hardness so that I would be testing the inherent difference in the alloy, not the heat treat. However, D2 can easily be taken to a significantly higher hardness than the other alloys. That adds back in the second factor that I was trying to eliminate.
I suppose I could try to find a D2 blade hardened to a 59, but I'll have to figure out who offers one. Bugger!
