- Jun 3, 2019
Nice ideas stacy. Thank you!
Usually i eyeball it also… but when i am making a wa handle, it takes a greater volume to fill the cavity, and eyeballing it just becomes a little less precise (hard to judge) because of the way the two layers sit in the small dixie cups i use.
I use gflex .. it only says 1:1 … but does not indicate by weight or volume. I think there us a fair amount of leeway in the actual ratios. Like i said, im just after reducing the occurance if where one bottle is empty and there is still a fair amount of resin left in the other bottle
Actually, you can get by without the calibrated weights: one ml of water = one gram. That is how i finally proved to myself that my whole digit resolution scale is so far off in the 1-5 gram range.There are cheap little scales that do grams well.
Look for the scales taht have 0.0 gram resolution
They often have different ranges
I have two scales
0-200 grams 0.0 readout
0-2,000 grams whole number readout.
0.01 gram resolution is pretty damn small, that's high dollar lab scale territory.
If you're not paying for it, it's probably not working well.
Buy a couple of check weights to check the scale with
One at each end of the range to make sure it's linear
1 gram and 200 gram weights are cheap,
$20 Canadian $ with free shipping for a whole weight set.
More if you get one that's NIST traceable.
There is definitely tech data for weight ratios.
It would be really interesting to compare that to NIST weights.Medical syringe
I would think a true NIST weight, traceable to standards, and clean and well maintained would technically be much more accurate. With the syringe you have its own inherent accuracy of the markings (accuracy of something like 0.05ml), plus you also have variability due to the user ability to see/control the location of the plunger.It would be really interesting to compare that to NIST weights.
I've been building laminated fiberglass traditional bows for close to 20 years now. Let's just agree maybe that glue is really important for this task. A working limb that flex's and recoverees to it's original shape Thousands of times over and over. Maybe just maybe more so than attaching scales to a knife blank. I"VE NEVER had a glue failure or actually any failure in that time simply doing volume measurements. I'm talking multiple level spoon fulls of equal volume to do a layup to make a bow. I'm guessing most glue failures is from poor prep, poor temps during glue up, not enough of mixing the two parts or excessive clamping pressure. YOUR mileage may vary.And you can go 20 more without a hitch, thats completely fine. I moved to syringes and a scale because I buy epoxy by the kilo, so I put enough on a couple of syringes, mix exactly what I need and waste almost nothing, just a saving and efficiency thing.
Pablo
But the accuracy of the weights is way overkill for my needs. I tared my container, put in one ml … the scale indicated zero. Put in ANOTHER ml of water … the scale still read zero. Got to 4ml of water before the scale read even 1 gram
Well, the container i used (and tared to) weighed several tens of grams, if that is what you are asking?Yes, that's out of whack.
have you tried that again, but tared in the middle of the range ?
Pablo threw out right away that kitchenscales are only accurate to like 5 grams … which is in line with what i saw
Oh funny. I remember back then the boarder inspections were really focused on drugs. I suppose they did not quite buy it when you said you were using it to measure out portions of epoxy???I really appreciated the side discussion on dixie cups and silicone cups for mixing and mini funnels and stir sticks.
I bought one of these mini gram scales on ebay 20 years ago to measure arrow components for my bow. Can set the scale to grains or grams....15.43 grains in a gram. So good and accurate for what we are doing.
Funny part was I had to pick it up in the States and the border agents were sure I was dealing drugs and the scale was for measuring them. My car got a good search and sniff from the dog that day. I was thankful I didn't get a cavity search!!
