- May 15, 2012
Bump for info re heat treating issues.
My 0560BLK which has been sharpen to convex edge chipped just by cutting some cardboard.
Haven't seen any problems with ELMAX in the various knives I have seen with different grinds and various HRC ranges from 58 to 62.
The Kai representative who used to post here denied heat treatment problems existing.
20 degrees per side is thicker than angles on an axe. That shouldn't chip.
Hey Ankerson, I've read most of your research on here, and thanks for the input. Haveyou ever had experience with these steels in colder temperatures, or even bellow 0? I have seen several reports that it can change some of the properties of some steels, but I wanted to know if you knew anything about it.
I try to replicate the grind angle that is currently on an axe when sharpening. For years, I might as well buy an new axe as sharpen up an old one unless it was on a bench grinder which I avoid using for anything I care about.
