- Sep 3, 2012
I got a Zero Tolerance 0560 recently, and wanted it partly because of the good things I had heard about the new Elmax steel; one thing people said was that it is very tough.
In the days after I got it I went into the woods to do some testing. One thing I tested was the stabbing ability by stabbing it into a tree in forward and reverse grips a total of less than 10 times while not even using my full strength, and I'm not a big guy.
When I got home I could see that the edge had been flattened from the tip to the exact point it stopped penetrating into the wood, and confirmed this in paper cutting.
I have done similar tests with 440c, 420hc, 14c28n, s30v, and s35vn with nothing similar ever happening.
Is the steel not tempered properly, thin edge geometry (the grind is noticeably uneven), etc.
I would like to know what the issue is and if anyone has experienced this before.
