Tree stabbing isn't what I consider a test nor is it knife use, it's just pointless, pun intended.
I didnt mean to sound like I was hating it for no reason. Its all just personal preference. I have seen 3 threads, including a video, that show really soft, rolling steel in the Elmax 560/561's. I personally think the knife is slightly too big for my EDC's. Take the size, and the steel and thats why I passed up on it, but that doesnt mean its the wrong knife for everyone.
The only problems I see with the test is that it is not well controlled nor anywhere near taxing enough to any steel to discern a difference. But I am of the idea that wood tends to not cause steel a great deal of trouble. Something about saws, axes, drills, chisels, rasps, gouges, and such.I have done similar tests with 440c, 420hc, 14c28n, s30v, and s35vn with nothing similar ever happening.
And yet other knives in other steels that are much less expensive are capable of it without the edge flattening noted on the Elmax blade.
Just so everyone is clear, can anyone list the intended uses of this or other ZT knives? Failing that, can anyone list discouraged uses? Hinderer knives and presumably his designs for other companies are billed as rough use blades with better than normal durability. If the rather tired notion that knives are only for cutting is to be applied to this design, can someone explain the use of saber ground blades made from stock greater than 1mm in thickness with edge angles greater than 12 degrees per side?
To the starter of this thread, can you get all your knives together with fresh edges and repeat the wood stabbing on something like a 2x4, for the sake of consistency, and see what happens then? I still think you may have an overheated edge from the factory. If you haven't already sent it back, resharpen it a few times. It's also very possible you have a tree with some nasty inclusions. You can find trees with nails, arrow heads, barbed wire, etc here without looking very far.
