- Apr 15, 2012
My Example: ETAK-B V-Grind Primary w/Chisel Secondary applied to left-hand side.
I have often wondered (actually discounted the brand because of this) why Emerson knives Chisel grind is typically on the left-hand side of their right-handed knives?
Seems to me to be a right-handed knife with a left-handed grind.
In general, I have assumed this related to being on the "presentation side". Is there any perforce based reasoning behind this geometry?
I sometimes sharpen asymmetric secondaries, but typically will put the flatter bevel on the left side of a right-handed knife as it cuts better in my opinion and is easier to control. Steeper angle to the right or away from media being cut pushes cut material out and away. (Visa-versa for left-handed use.) Examples: Feathersticking Chisel pushes wood curles away from media, Food pushes away from media, Easier to resist the turning forces that asymmetric grind creates if chisel facing outwards.
I would appreciate any knowledge replies to help me to understand the principal's behind this design.
Please don't simply quote things like references here as I am aware (my above statement related to the "presentation side" answer):
http://emersonknives.com/ek_faq/why-do-you-use-the-chisel-grind/
http://emersonknives.com/ek_faq/why-do-you-put-the-chisel-on-the-front-or-left-side-of-the-blade/
Thank you,
Thank you,
