- Aug 10, 2007
I'm thinking about getting a cqc14 for a work knife(construction), and am a bit concerned about it having a liner lock. whats the overall opinion of Emersons liner locks?
Dave
Dave
Dave
whats the overall opinion of liner locks?
Dave
Personally, if I buy an expensive high quality knife it is for self-defense, and I don't use it for anything else. For work, I have a hundred cheaper knives that I don't care if I ruin....
what exactly is your concern? liner locks are very secure, and the emerson's are no exception.
i would suggest periodically checking the pivot screw. if the blade has some lateral play, a loose pivot screw is likely the culprit, and can also contribute to lock failure.
I would suggest taking it slow until the lock moves in behind the blade better than most of them do when you first open it up and start using it. If the lock is barely engaging the blade at all, as many of them do and all four of mine have your fears are certainly justified. It may hold just fine but it will at least have more meat behind the blade once its broke in.
The 14 is one of my favorite handles of all time; as I do love the shape and Ernie's ergonomics but I've been wary of the liner lock also, so I'd have to say it depends on the type of uses you are planning for it. Many people are quite happy and content with the liner lock while others are running around with permanent nerve damage to their fingers from letting their guard down with one or using it the wrong way. I have more emails from end line users with complaints and concerns about this type lock than all the other style locks combined. In other words you are not alone with your feelings.
Regardless of what the 'in crowd' tells you, their beliefs are based on blind faith. These locks need to be used with caution when used hard where twisting and leveraged torques are applied to the handle. When you take what is essentially a gents liner lock, which is what that is at .050 thickness titanium, and you beef up the pivot to a nice bull size of a 1/4", beef up the stop to a bigger diameter of 3/16", give it a nice tactical look and feel, and some G10 black grippy handle scales and leave the lock alone with out making any changes to it its my opinion that the knife is nothing more than a sheep in wolfs clothing. Underneath its really still just a gents liner lock and it should always be treated as such. And I'll argue that to my grave.
STR
Right now I'd say the liner is engaging ~80-90% of the lockface, and does this quite smoothly.
I'm not rough on my knives as I have other tools for prying, and twisting, so I'm not really concerned about torquing and twisting the blade. The worst I would probably do to the knife is get it full of dirt or mud...which I'm hoping I'll have enough sense to clean it thoroughly before using it again.
While I feel the lock is pretty secure as it is, I am considering sending it to you to have a framelock conversion done to it. I noticed you have another 14 in line for a conversion.. maybe I can get mine to you at the same time you start this other one...while your tooled up for 14's. I also would like the wave removed from mine, as this is a work knife and not for self defense ,I don't need the blade opened everytime I take it out of my pocket.
dave
STR
