Wowbagger
- Sep 20, 2015
Bowerick Wowbagger The Infinitely Prolonged Reporting :
First a question for Ankerson :
serious questions for info to make up my mind
Ankerson after you got done cutting all those feather sticks would the edge bite your finger nail ?
Would the edge shave at all ?
I am trying to get a handle on what to expect and what to tell Spyderco.
every body
So I decided to follow Ankersons advice and call Spyderco to send my Manix to them for inspection.
For those who have not been following the story it is quite simple; I sharpen it. it goes dull too quickly
. . . faster than even a S30V blade. I sharpen it. it goes dull. I sharpen it with diamonds and a strop it goes dull. I sharpen it with a set of Shaptons and mirror polish it and it goes dull.
Quick . . . in a day or two. Other knives : S30V, CTS -XHP, ZDP-189 . . ., M390 all hold up much better; some for a week or so. Same exact materials cut. Daily at work.
So anyway . . . I thought the steel was soft; heat treat problems, because the edge rolls and dings as well as dulls quick compared to the others . . . the M390 especially (with a significantly thinner blade behind the edge) goes for five times longer.
So . . . I figure I will put my best foot forward and sharpen the edge to one consistent bevel (I have been going a degree or two steeper all along for quicker and better sharpening but have maintained as much as possible the same geometry it came with).
Now I had just acquired , after being out of stock for 7 months, a Shapton 220 stone for the Edge Pro and put that baby to work (a fresh stone mind you) making that bevel all nice and consistent. After a while things began to change and I had a revelation . . . the knife was getting hard to sharpen . . . I was whizzing away with the Edge Pro and rinsing and rinsing the stone and sawing and sawing but that wide bevel wasnt changing near as fast as my other knives. Finally I switched to the Shapton 120 and did the same. A bit better but it was clear by the minuscule progress that I was making that . . .
The steel was plenty hard and tough.
Hmmmmmmm
Well after much time and effort I got the bevel consistant and wire edge free (not that there was ever anything but a very small wire edge) and mirror polished and hair whittlingly sharp.
NOW what do I tell them when I get on the phone to Spyderco ? ? ? ? ?
Before . . . this last sharpening I planed to take the sharpened Manix to work for one day and use only the front half of the blade and then ask them to inspect the edge. The back half would prove it had been indeed adequately sharpened and the front half would show the degree the edge deteriorated from what I consider light, everyday and non abusive use. Use less than cutting rope partly because I NEVER cut against a cutting board just sliced , cardboard, rubber coated cloth and trimming hard rubber.
So it is hard. Now what do I do with it ? ? ? Sorry some how I couldn't resist saying that.
Maybe I had been temporarily crazy all these months and now the fog had cleared and the knife would hold up as it should. It was all just a crazy nightmare brought on by too much contaminated chocolate or something.
What joy if I didnt have to send it back at all but just keep it as is and use it.
I took it to work. One day. Of even lighter than normal use. The edge sucks; once again.
It is not chipped in the least. Seems to have ever so slight rolling and just general dulling. Wont bite my finger nail except where I didnt use it. No part of the used edge will even begin to shave arm hair. The M390 blade which has basically never been sharpened since I got it and only some light stropping once on one Sharp Maker ultra fine stone part way through 12 days of the same use WILL bite my nail ALL ALONG the length of the blade and will just barely shave arm hair with much difficulty.
Is this just how S110V is ?
It wont be any good for the trimming I have to do.
All it is good for is chopping rope ?
I have never felt more lost about a tool issue. It seems to be hard but . . .
every body
Hmmmmmmm
