Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
One big improvement in installing a handle is creating a glue reservoir. Put a rough hollow grind down the center of the tang where the scales will be. Put a similar hollow on the scales. These don't need to be deep, a few thousandths is all you need. This way there is always a layer of epoxy between the scales and tang. One issue with clamping scales on a knife is squeezing all the epoxy out of the joint. This is called a "Glue Starved Joint". It is very weak and merely dropping the knife on the floor or countertop can pop a scale off. I also drill extra holes through the tang to create "epoxy bridges". These also strengthen the handle a good bit.
Also. the tang and scales don't need a fine grit surface. 120 grit is perfect. I carry the blade finish back just past the front of the handle.
