- Jan 26, 2012
The original 4 sheath was kydex and had the adjuster screw.
Nope. That would be the 5 sheath. The 3 Esee 4 kydex sheaths I have had did not have the adjusting screw.
OK, I stand corrected on the 4 sheath about the adj. screw, but if you use the top holes in the old 4 sheath it will tighten it up also.
I would contact ESEE customer service, and see what they suggest. If it is a issue with safely removing the knife from the sheath, I am sure they will be glad to help you.
Rowen 1095 is the exact same metal as all other quality 1095. They make really well designed quality knives, but their warranty is a marketing device and I have received poor responses from the co-owner.True, but if the problem is a poorly molded sheath, I'm sure they would sort it out. It more that they don't put the bomber warranty on the sheath because they didn't make it out of rowen 1095![]()
Sent from my SM-G920V using Tapatalk
But, with a more consistent and higher quality heat treatment then many/most other companies. Better fit and finish as well. As for their warranty, whether it is partly for marketing or not, it is one of the best in the knife industry. There are not many companies that will replace your knife no matter what if you have an issue.
Yeah, you're right. It isn't the point of the thread, but I hate to see someone buy a knife because of its warranty by the suggestions of people who might or might not have experience with the warranty, when I know their advertising is not reality.It was a joke. Not many knife makers warranty their sheaths, and the ones that do, have a really solid sheath-maker backing them up. ALLHSS, I feel bad if you got the short end of their attitude, it does rub some the wrong way, but that's not the point we are after.
There's no magical heat treat of 1095. I agree that they likely are very consistent with a high quality heat treat. However, tests show that it doesn't improve performance to a considerable degree.
That has not been my experience. I had to drag any modicum of service out of them, and I don't like pushing that kind of thing or having to take advantage of things like that. Their warranty is vague at best and possibly deceptive in their wording. They use a picture of a knife that someone shot as an example that they will replace a knife with no questions, then say that the handle and hardware is not covered by their warranty (and call a customer derogatory names and ask that they don't purchase their knives anymore) if they try to get a REPAIR (not even only a replacement).
On the other hand, there are companies that word their warranties much more restrictively that have provided much better service with much less grief.
I really like several of their designs, but their business practices are not something I want to involve myself in unless there are no comparable options.
would that be about a retired military discount?They make really well designed quality knives, but their warranty is a marketing device and I have received poor responses from the co-owner.
