It's 1055 steel. My axe is 20 years old and I can tell the hammer head is softer than the axe face. It takes and holds a good edge. I suppose you could weld a harder metal piece to the cutting face. Then shape that. I think a simpler route would be to give it a cryogenic treatment. A long soak in dry ice would pick up the hardness a point. Then give it a stress relieving quench with a torch wrapping the leather handle, to isolate the head. Could work. A weekend project. DM
Most axes are. The bits are usually induction heated and then quenched/tempered. Though it'd be curious if Estwing was actually using that process since they have the neck and tang of the handles at spring temper, and maintaining that would be tricky to do a differential on.
Estwing deferentially hardens their tools? Wow, that's interesting, and impressive! I wonder what hardnesses they use?
Someone here said these hatchets are date stamped. Is that stamp at the butt of the handle?
Thanks, DM
From the video it appears that they heat treat and quench the entire head.
However, wouldn't the edge heat/cool faster than the other thicker parts?
Allowing the edge to be harder than the rest of the body?
