The test looks well controlled, but I'm having trouble believing the results.
Jim has done extensive testing in the past using a different measure of sharpness and found huge differences in wear resistance. Those results mirrored the general results that others have gotten.
And now it's all about sharpening? Nothing else. The steel alloy doesn't matter?
What I have noticed is that different testers have come up with much different BESS scores. Even in Jim's tests, where he cuts off the test when the edge reaches a specific level of dullness. The end-point should show the same BESS score. But the early results have been widely disparate.
Something is wrong, but I don't know what it is. I do not believe that high-wear steels don't offer a wear-resistance advantage over relatively simple steels.
are the values you give in your test above in straight grams, or are they scaled to the BESS scale, which appears to set 0 based on the sharpness of double edged razor blades? This appears to be 50 grams based on DE razor blade measurements.
I only tested for the 1st 5% to 6% of the dullness curve.
Like the title of the thread says Extreme Sharpness comparison.
Fair enough. Oddly, though, we always hear that the high-wear powder steels lose their sharpness quickly, then retain a working edge for a long time. Not so in this test.
Maybe -- I'm guessing -- that at 400 grit you're tearing out the carbides in the S110V, leaving only a jagged edge of the steel matrix. Or maybe those jagged edges left by the coarse stone don't hold up very well to abrasive cardboard, regardless of the carbides.
I'm still left with the impression that the BESS score is not ready for prime time. We've seen a lot of quite different scores for edges of equal sharpness.
On your test of S125V with an edge shoulder width of 0.006 inches, the edge was still cutting rope at less than 20 pounds up to a BESS score of 621. With Niolox steel, at the same edge-shoulder width, the edge was cutting rope at less than 20 pounds up to 344.5 BESS.
I don't see anything wrong with your testing procedure -- isolating key variables to test for extreme sharpness on a coarse edge -- but it would be an amazing finding if high-wear, high-alloy powder steels don't offer a huge advantage in wear resistance.
Were you slicing with the whole edge or just using a limited section?
I like this device. Would be curious to see what would happen to the initial sharpness if one would drop the edge angle lower and lower until you end up with a zero blended edge.
What kind of stones did you use? Since vanadium carbides are harder than alumina oxide, I wonder if that plays any role when going for a polished edge.
Very good thread Jim. Another surprise. It seems like you could write a few articles putting together some of the things you have done the last few years. Heck, a book.People publish books with less raw data than you have accumulated over the last few years.
Posting those results here will have people asking for more testing from you.I can donate some money for supplies if needed. Just let me know.
Joe
I'm not even sure I understood all of what was in the original post but it sounds good Jim. :thumbup:
Keep on keepin' on...![]()
