- Dec 10, 2003
uppin for the night crowd
Originally posted by kevtan
I get the impression that I would need to get the polishing tape mounts to mount the diamond hones, is this right?
What you need to ask Ben to sell you are the beveled blanks, without spacer on, and
you stick the Diamond plates directly to them.
Explain to Ben what you are up to . He knows what you need.
kevtan said:Finally got my edgepro apex from JF Jensen via www.knifeworks.com to save on postage. I also got the ungrade kit. Now all my knives have a nice shiny bevel!!! Only problem is the stones hardly makes progress against s30v(dominator,LF TighePan) , vg10(endura) and M2(710hs). So am planning to get the diamonds. All three of them, so there....!!
Do you guys have problem holding the knive with your right hand and the hone, the left hand? It feels kind of akward and bleh! So whats the solution if any?
He maintains that the design of the EdgePro will allow far too much pressure to be placed on the diamond hone and this 'pressure' will literally rip the diamonds from their electro plated base.
In another life, I am involved with the 'Gem Business'
We use diamond exclusively to cut gemstones. The 'laps' are 8 inches in diameter and most have the diamond electro plated as the bond method.
A very gentle touch is required with lots of water as a lubricant and coolant. A novice cutter can destroy a $200 lap in five minutes.
Cause.
Too much pressure.
I was taught again and again. Let the diamond do the work, not hand pressure.
Does anyone know where I can get a 42C ?
This need to be repeated whenever diamonds are mentioned., slower, lighter does the job.
Avoid EZ-Lap's hype and never buy EZ-Lap when you can get what you need from DMT, much nicer people and better products.
