- Jul 20, 2021
That's done using coarser materials. They can grind them out much faster that way.
Have you ever worked on a production line? Is everything You do in your job perfect, the first time every time? I'm sure they have people that all they do is sharpen knives. It's all they do all day. And most get very good at it. But they are sharpening knives freehand, on a belt grinder. They have hundreds of knives each day to sharpen. They probably have less than a minute per knife. The guys that are really good probably miss on very few knives. The average guy misses on a few more. The new guy on the job, or the goof off that doesn't care, they might have trouble getting as many good sharpenings as bad ones. But nobody is perfect, nobody will get every knife perfect every time.I don't understand why every knife doesn't come from the factory with a shaving-sharp edge. Presumably manufacturers have a person or persons whose job it is to sharpen their knives before they go out the door. These folks likely have thousands of knives under their belts. They should be *really* good at sharpening, and it doesn't take long to put a hair-splitting edge on a knife using a belt grinder. But I can count on one hand the number of factory-fresh knives I've received that satisfy my (admittedly high) standards for sharpness.
Then QC pulls it and sends it back to be touched up. Multiple people have messed up when a knife leaves a factory with a bad edge. They grind them coarse because it is cheaper and faster. It costs more time and consumeables to getter a finer edge.Have you ever worked on a production line? Is everything You do in your job perfect, the first time every time? I'm sure they have people that all they do is sharpen knives. It's all they do all day. And most get very good at it. But they are sharpening knives freehand, on a belt grinder. They have hundreds of knives each day to sharpen. They probably have less than a minute per knife. The guys that are really good probably miss on very few knives. The average guy misses on a few more. The new guy on the job, or the goof off that doesn't care, they might have trouble getting as many good sharpenings as bad ones. But nobody is perfect, nobody will get every knife perfect every time.
O.B.
I knew going in to ordering the knife that I wouldn't be happy the obtuse edge they're known for but was amazed the bevels were not ground to form an apex. Not a huge deal because I'd already planned on stripping the blade and hand grinding a proper cutting edge when it finally arrived.I understand the many reasons a knife could leave the factory without a good sharp edge, however it is frustrating when you’re talking about a $200 + knife. At around that point I feel it’s reasonable to expect the maker/manufacturer to prioritize a proper edge. In a “higher end” knife, QC should send back anything that doesn’t cleanly slice paper/shave arm hair imho.
Why don’t they? Well probably because we keep buying dull knives and not complaining about them/sending them back.
Btw I’m guilty of this too - I’ve had a couple of Swamp Rats that were inadequately sharp on delivery, but I keep buying them anyway!
Kizer and Spyderco always seem to have good edges on them. I've been using my Gayle Bradley 2 for almost a month with just stropping and it will still shave. I don't mind putting new edges on knives but it's nice getting to open one up and put it right to work.
In my experience Hinderer has the absolute worst factory edges. Ricks “working edge” is just a cool way to say completely blunt.
At those price points I guess I expected a little better? Good knives though still.Hinderer seems very inconsistent. My xm-24 was great, no need to reprofile. Both my xm-18s (standard slicer and a skinny slicer) had horribly obtuse angles. They were sharp, and cut, just not well at all. Took them to 17 dps and the skinny is actually a great slicer! The standard cuts well but being of such thick stock it can be wedge-like. Still an amazing knife though, and one of my favorites.
<pre>
Sharpness measurements (BESS scores) on 96 blades using an Edge-On-Up PT50A.
The blades had previously cut nothing more than a piece of computer paper.
The column labeled Sharp is the average of 5 or more measurements.
The value of Sharp is also plotted as a hash/pound/number sign.
Individual measurements are plotted as dashes.
Sharp Steel Make Model 0.........100.......Sharpness Measurements in Grams.......500........600 Price
40 ? Goodline Double Edge Razor Blade @B . -#-- . : x . 0.76
46 ? Goodline Double Edge Razor Blade @A . -# . : x . 0.76
128 CPM-SPY27 Spyderco Para 3 Blue @D . -#-- . : x . 140.00
129 AUS-8A Cold Steel Finn Wolf Orange . ---# . - : x . 43.99
130 CTS-BD1N Spyderco Manix 2 Blue . - # - . : x . 105.00
132 M390 Bradford Guardian 3 Blue . -- #--- . : x . 169.95
135 AUS-8 CRKT Nirk Tighe 2 Blue . --# - . : x . 82.95
136 Elmax Bradford G-Necker . -#- . : x . 79.95
143 AUS-8 SOG Flash II @B . --#-- . : x . 62.95
145 AUS-8A Cold Steel Tuff Lite Red . -#- . : x . 27.99
147 440C Maserin 975 Sax (Combo Smooth) . - # - . : x . 67.96
148 CPM-S30V Spyderco Sliverax . - #-- . : x . 177.80
148 CPM-S45VN Spyderco Para 3 Black @C . -- # - . : x . 147.00
150 5Cr15MoV CRKT Folts Minimalist Bowie Neck Black @B . - #- - . : x . 25.95
... a whole bunch of data omitted to stay under 10000 characters ...
314 440A Marbles Large Lockback MR565 Orange . . -- - -: # x -+ 9.99
330 Tru-Sharp Case Tribal Lock Orange . . - - : # - - x - . 55.99
336 AUS-8 Camillus Mountaineer (Combo Smooth) . . -:- # -- -x . 56.66
359 AUS-8A Spartan Blades Enyo Bronze Line Field Grade Neck . . - - : -# x - - . 88.00
359 8Cr13MoV CRKT Ryan Johnson RMJ Owlet Neck . . - : -# --- . 22.95
416 ? Frost Fire Fighter Red . . : - - x-# - - . 10.00
433 CPM-S35VN Spartan Blades Enyo Elite Gold Grade Neck . . -- -x # --+ 150.00
471 H1 Spyderco ARK Neck . . : - x # -- - . 77.00
553 12C27 Opinel #8 Outdoor Folder(Combo Smooth) . . : - x - # -+ 39.00
784 ? Chinese Eagle Auto . . : - x - -#+ 12.00
</pre>
