Kershaw ENER-G II from Kershaw's site:
A new breed of easy open knives, the Ener-G FLIPPERS designed by Lee Williams, incorporates his patented "pseunetic®" opening feature. The blade is held in the closed position until deployed by pulling on the extended tang located at the front of the spine. This action allows the blade to open quickly and easily.
SPECIFICATIONS:
Made in the USA
Steel: Sandvik 13C26 stainless-steel
Handle: Textured black G-10
Blade Length: 3 1/2 in. (8.9 cm)
Closed Length: 4 3/4 in. (12.0 cm)
Overall Length: N/A
Weight: 4.9 oz.
FEATURES:
Locking Liner
Pocket Clip
The prototype was called the NRG, but there was some licensing issues surrounding that name, so Kershaw changed it to ENER-G. Designed by Lee Williams, they are not AO's, but have a unique flipper system. The flipper is not part of the blade. It is a separate piece that multiplies the force your finger gives you. These, with a little practice, will fire open as fast if not faster than the SpeedSafe AO's.
They come in two sizes: The II has a 3 1/2 inch hollow ground 13C26 blade, while the standard ENER-G is slightly smaller with a 2 13/16 inch blade. Same grind, same steel. These knives produced after January 1 will have Kershaw's exclusive 14C28N steel. Tip up or down, right hand.
The two models shown have been modified a bit...the black DLC coated blade and black clip belong on the black G-10 handle. I was messing around with them and decided to swap a few parts out! The all black models were a limited production run, yet still can be found at some on-line dealers and internet auction sites.
With a ball detente, I don't think you would have any problems with customs, but then again I'm not a customs agent.
These are fantastic slicers, and as I said, a little practice with the flipper system fires them extremely fast.
Lee Williams and Kershaw have also come up with another unique flipper system that will be put on the new OD-1. Expected to ship in the next week or so, the OD-1 will be a 3 1/2 inch stonewashed 14C28N blade, non AO, tip up/down right, up left (I think), frame lock with a G-10 slab on the non-lock side. It will also come with a Hinderer lock stabilizer, and be available in a smaller size.
Sweet, huh!
