- A knife is designed with a certain edge angle and thickness. In theory, this should be the optimal design for the intended use of the knife.
That's a huge assumption and one I completely disagree with. While it may be the manufacturer's chosen angle for any number of reasons, to assume that the factory edge angle is in any way optimal doesn't make any sense. The manufacturer has no idea how a user intends to employ the knife and what edge will be suitable for their needs. What edge is most effective depends on a number of factors that knife companies can't come close to guessing. It's fairly common knowledge that most manufacturers edge their knives at an angle that will hopefully last a long time without significant deformation. That's all.
If the edge is ground thicker than intended (which appears to be the case for the OP for the portion near the heel), performance will suffer. If it is ground thinner than intended, durability will suffer.
Based on what? What performance? What materials are being cut? What tasks are being performed?
- Allyourblood: I don't understand the point you're trying to make when you say you never mentioned on the forums the bad grind you got from benchmade.
Really? You argued that people were making excuses for Spyderco's factory edge based on who they are and not on the value of the knife. You also implied that a $40 knife is not what "normal people" consider to be cheap, and therefore at its price point, the edge should have been more evenly ground. I disagree with that and offered my example as support of my opinion. The company being Spyderco had little to do with people's opinion that the OP was making a mountain out of a molehill. The knife being $40 had little to do with people taking a relaxed attitude toward the uneven grind. It just wasn't that big of an issue, and while no one minded it being mentioned (as far as I can tell), folks were more offended by how it was
worded.
Apparently this grind was off by enough that years of sharpening could not correct it, yet on the forums you just went on about how awesome it was?
Yup.
The two are not mutually exclusive. Years of regular sharpening didn't change the uneven grind in the blade toward the spine and probably won't for a long time. Despite this, the cutting edge was shaving sharp upon arrival, and has remained exactly that throughout the years. It's an excellent knife and its cutting performance is unaffected by the uneven grind in any way, other than aesthetics.
Even if it was your favorite knife despite the grind, that info would have been valuable to people who do care about such things. Instead, they got unequivocal praise.
You're darn right they did. As I mentioned, the uneven grind hasn't affected the knife's performance and was, in my eyes, well within spec given the knife's price point and my own expectations. For $100, I find it completely acceptable. Am I somehow under obligation to volunteer information about my property that I find wholly arbitrary to its overall performance and my own satisfaction? You seem to imply that I've done the knife community a disservice by not sharing what I considered to be a rather insignificant detail; that instead I somehow deceived them by omitting what is apparently a colossally important... *shudder*...
"data point".
You might want to hear about a knife in its entirety, "warts and all", and that's fine. But I have no expectations about what people are willing to share, and I don't think anyone else should, either. I chose not to share the aforementioned info and I don't feel the community is any worse for it. The OP went the other way, and well, are we that much more enlightened?
