- Mar 28, 2020
Funny that the "more expensive" the knife, the easier to ruin. Those hand grind sharpening kit doesn't generate heat, you use grind it slowly.
My CHEAP knives can cut paper strips like air, what else do you want?
Well ruin is the wrong word what he means is damaging the heat treat at the edge by using dry belts. You have to remember how little of steel we are talking about. It is easy to damage the heat treat on such a small area and not even know it. And you won't even feel it or see it most of the time.
Sure, it will cut paper but when you put it to a real test the edge will roll or chip. If you use a belt grinder it needs to be a wet setup that sprays a cool water mist onto the blade while grinding. At least that's what the experts say. I bought a Wicked Edge so I wouldn't have to worry about it.
I believe that most people that complain about good steels performing poorly, burned the edges of their blade and don't even know it. Of course, you can fix it by sharpening the edge down until you get to good steel that hasn't had the heat treat damaged.
