I don't think the other techniques are "silly" as you say.
Drawing the edge through a block of wood to remove the burr is . . . in a word . . . silly.
It is even sillier when it is done on the edge of a stone pond with grit all over it as I have seen in videos.
Now lets look at deburring on the edge pro. I normally pull the stone edge trailing. I get some extruded or burnish formed bur from this. I would probably get less if I followed the rules and went back and forth as the edge pro vids show. I don't go against the edge for two reasons :
- I don't want to wear the stones. I have a real problem with going against the edge and wearing the stones. This is probably why I gave up hand held sharpening early on. For the most part. You know what ? I still have my original King water stone that I bought in 1985 or so and it is still nice and thick even though I used it a whole heck of a a lot WITH A JIG before I got my Nortons and then My Shaptons and then the Edge Pro .
- I don't want to bang into the edge with grit.
I can just imagine all that slurry and loose grit colliding with the edge and banging it up. I just can't do it.
So I have a burr. Now I take as was recommended some passes against the edge, one or two per side, very light. But often I don't make the sharpening angle steeper I just simply make the pass just against the edge and lift.
Now I make two or three pull only passes alternating sides and we are done.
If that doesn't do it, say we are sharpening cheep stainless then I might make two passes per side against the edge, swap sides and two then one and one.
This is done only on the very finest stone. All other passes with coarse stones are trailing edge unless I am taking off a bunch of metal on the roundy round con vexed edge with the coarse stones then it is like sawing logs and it just makes sense to go back and forth.
As far as spending most of the motion just back of the edge then going up to the edge and taking a couple hits there then going back behind the edge that is how I sharpen drill bits by hand. It works very well.
Still if you think about it on a jig all you have to do is take like a third of all that motion, basically right on the edge and be done.
Sharpening while holding the stone in one hand the knife in the other is good. I made these, cut offs from Nortons stones (4000 and 8000) using the ends for polishing the sides of blades and I found myself using the sides for sharpening touch ups . . . pretty much a substitute for stropping if you will. Most of my work edges are a bit too banged up microscopically to take to a strop but still cut well enough. Some times I don't want to compete with The Chef for counter space to use my Edge Pro while she is cooking dinner so I sit on the couch and use these stones dry, after all there are three sides to the stone that are useable. I use a jewelers visor and get the light in such a way I can see a shadow / gap at the edge. When I just close that gap that means I am ON THE EDGE and I take a pass. Sloppy but effective.
I hate the imprecision of it and use the Edge Pro when ever I can.
By the way gang that is ZDP-189 (plenty hard judging by how well it holds up in use). No prob with micro chipping. Only chips if I cut wire ties. I learned not to cut wire ties with this knife and never a chip since.
HeavyHanded,
Those are some fine illustrations. You are obviously a professional illustrator or could be if you so desired. NICE !
And yes I am learning stuff . . . reluctantly . . . kicking and screaming all the way to the ice cream shop.
