I have lots of knives which would not pass these tests for various reasons and I would call them hard use, and I have knives that would pass them and I would not call them hard use.
This interested me, so I follwoed the link and here are the tests:
1. ROPE CUTTING: THE PURPOSE OF THIS TEST IS TO TEST THE EDGE GEOMETRY AND SHARPNESS.
Applicant is responsible for supplying the test rope and ensuring that it is a minimum of one (1) inch in diameter. If the applicant brings a larger rope, the applicant will be judged using the same criteria as though the rope was one inch in diameter. The rope is to be hung in a safe manner, so that the end of the rope to be cut hangs loose without touching the floor or any other object. As a safety precaution, the rope is not to be hand held by another person during the rope-cutting test. The hanging end of the rope is to be marked with tape or a marker to clearly indicate the area that is to be cut. The cut must be approximately six (6) inches from the end of the free hanging rope. A minimum of one (1) cut must be made.
The applicant is to aim at the mark with a two (2) inch margin of high or low being acceptable. The applicant must sever the rope in two with one stroke. If the applicant fails on the first attempt, the Master Smith will allow two more attempts. However, if the Master Smith believes that the failure to sever the rope is due to the lack of skill or strength of the applicant, the Master Smith may attempt the rope cutting with the test knife. This is a test of the applicant s ability to make a knife, not to cut with it. If neither the applicant nor the Master Smith successfully cuts the rope, the applicant fails.
2. WOOD CHOPPING: THE PURPOSE OF THIS TEST IS TO DEMONSTRATE EDGE TOUGHNESS.
The chopping test is to be conducted with 2x4 construction grade wood stud of the applicant s choice. The 2x4 may be either hand held or clamped into a vise or other safe devise. A chopping motion (no whittling) is to be used. The 2x4 must be chopped completely through a minimum of two (2) times. The applicant may choose the area of the 2x4 to chop through.
Following the chopping test, the Master Smith will inspect the edge to determine if there is any noticeable damage to the blade. Any nicks, chips, flat spots, rolled edges, or other deformations of the blade will result in failing the test.
3. SHAVING HAIR: THE PURPOSE OF THIS TEST IS TO DEMONSTRATE EDGE RETENTION.
After the Master Smith approves the quality of the edge, the blade will be returned to the applicant. The applicant must then shave hair using the section of the blade that was most frequently used in the cutting and chopping portions of the test. Enough hair must be shaved to demonstrate that the edge remains keen and shaving sharp.
4. BENDING: THE PURPOSE OF THIS TEST IS TO SHOW THAT THE APPLICANT IS ABLE TO HEAT TREAT A KNIFE WITH A SOFT BACK AND A HARD EDGE.
The bending of the blade is the final test. Safety gear should be worn. At the discretion of the applicant or the Master Smith, the edge may be dulled prior to bending.
The Master Smith will mark a line across the width of the blade approximately 1/3 distance from the tip of the blade. The blade will then be inserted into a vise, tip first, such that the blade is placed into the vise up to the mark on the blade. If the vise jaws are rough, smooth metal inserts shall be located on each side of the clamped portion of the blade to protect the test knife.
The blade shall be bent by force applied to the handle. A leverage device such as a pipe may be used as long as it does not pose a safety risk. The use of such a device is at the sole risk of the applicant and at the discretion of the supervising Master Smith.
The applicant will then bend the blade ninety (90)degrees. The supervising Master Smith will signal the applicant when the ninety (90) degree angle has been reached.
The blade is allowed to crack at the edge on bending but not beyond approximately two thirds (2/3rds) the width of the blade. However, if any part of the blade chips or any part of the blade or tang breaks off, the applicant fails. Because of the many variables in the size,
Geometry, and temper line of the blade, the Master Smith using his/her judgment, shall determine if the extent or location of the fracture line is acceptable. The decision of the Master Smith is final.
So, with these tests in mind, I think there are plenty of "non-hard use" knives that could pass these tests.
For example, I would be happy to video tape testing a Gerber Fillet Knife performing these tests without a problem.
Here is a picture of the knife:
The blade is about 10" long (that is a 7" knife with it), under 1/16" thick, less than an inch wide. It is very flexible, as you would imagine a large fillet knife would be. Blade material is M2 covered with chrome.
I have never chopped a single piece of wood with it, but I have no doubt it iwll chop through two 2x4's without issue. It can take impacts off bone without damage (accidental glances).
The MS test allows yout oo choose your won construction grade 2X4. Choosing clear pine would make this an easy enopugh test.
#2: Cutting a pice of 1" rope to check edge quality. This knife has an edge under .010 thick, under 15 degrees per side at a fine ceramic finish. It will push shve free stadning hair. It would be pretty fast in a nspa cut. 1" rope, I have no doubt it will handle taht with ease.
Arm shave: Even with very fine hair, not a problem. M2 offers great edge retention in my experience and none of the test being conducted will chip it, even run this thin. It will shave hair all day.
Flex test: Bend it 90 degrees? Sure, no problem at all. Heck, I will bend it like 270 degrees so the handle is touching the vice. This is a large flexible fillet knife, it will bend like crazy.
This is not a hard use knife at all, in fact I would classify it as a light use knife. I think that is the point Cliff is trying to make.
On the other hand, my Ranger RD9 is a very hard use knife. It will pass the first test (chopping, no problem, make it a cord!), but it does not have the edge geometry (yet, but it will
) to make a single pass through 1" line unless someone much more skilled was weilding it.
I am not strong enough to bend it 90 degrees even if I stood on it, it would take 2 men and a large cheater bar. It would not suprise me if the blade failed if bent to 90 degrees, but good luck getting it there.
So no, the RD9 would proabbly not pass the MS test. But that does not make it any less of a hard use knife, it is over built and durable as hell.
And no, I have never made a knife. . . .
