Chuck Bybee said:
...misconstrued several things I wrote.
You argued that the ABS tests demonstrate a knife is capable of hard use and specifically that they illustrate this for hidden tangs. This is very clear from your above postings, you even defended this proposition several times. The ABS tests do not demonstrate either of these for many reasons.
Here is what happened, you proposed the arguement, I opposed it, you defended it with an ad hominem reply. When Cashen interjected that the tests can not be used to draw such a conclusion you were reaching you could not obviously take a similar manner with him.
If an arguement is wrong, it is wrong no matter who says it.
Kevin R. Cashen said:
The human hand must be eliminated as much a possible before real test results can be useful.
To determine the materials properties yes, I would suggest a a series of standard blocks heat treated and have them tested to determine the charpy value, tensile and yield points, resilence, ductility, wear / corrosion resistance, etc. . Minimum values could be set based on what the current best smiths can achieve.
However when you are looking at how these hold up in a knife, eliminating the human hand is a very bad idea, well I don't think very bad is a strong enough term. A knife has to be designed with being used by a person which defines such aspects as handle ergonomics and security, vibration as well as the general combination of abilities that promote "good" performance in general.
Lets say for example instead of a person chopping a 2x4 you rig up a simple impact with a press. This sounds really "scientific" and is very accurate and precise at measuring something - but it isn't what you actually want to really measure, and it would allow a knife to succeed while the same blade would shatter/deform if a person actually tried to use it because people can't be so precise and you have to build a knife accordingly.
The difficult question is this - if a maker has a knife which allows him to cut through a 2x4 XXX number of times and have the knife have ZZZ% of the optimal sharpness, which is above the pass point, but when I try it the results are worse and the knife fails, does the maker pass or fail - how do you factor the skill level into the grade? I don't think this is a insurmountable problem however, you would just want to define this as well which takes some work but isn't impossible.
There are a tremendous amount of talented and gifted invididuals in the ABS, many of whom I have talked to and have the pleasure of learning a lot about knives, steels and use as well as simple personal viewpoints on optimal performance. I am confident if even moderate effort was put into the development of such standards that there would be working ones achieved in a very short period of time.
Anyone who wants to share such an opinion can pop over to SwordForums and read the posts in the metals and performance testing sub-forums and you will quickly come to understand the depth of knowledge that is evident.
-Cliff
