Ferro Rod vs. Misch Metal???
Forget what it's called. The people that use these terms are not precise. I never heard "misch metal" used for a fire-starting tool until Lundin's book came out, and he illustrated ferrocerium rods. Buy the one that works the best for you.
Ferrocerium is a man-made metallic material that has the ability to give off a large number of hot sparks when scraped against a rough surface (pyrophoricity), such as ridged steel. Because of this property it is used in many applications, such as clockwork toys, strikers for welding torches, so-called "flint-and-steel" fire-starters in emergency survival kits, and perhaps most commonly in lighters as the initial ignition source for the primary fuel. What is commonly called "flint" in modern times is actually ferrocerium. Also known as Auermetall after its inventor Baron Carl Auer von Welsbach, it is sold under such trade names as Blastmatch, Fire Steel, and Metal-Match.
While ferrocerium-and-steels function in a similar way to actual flint-and-steel in fire starting, ferrocerium actually takes on the role that steel played in traditional methods: When small shavings of it are removed quickly enough, the heat generated by friction is enough to ignite those shavings. The sparks generated are in fact tiny pieces of burning metal. In traditional flint-and-steel fire-starting systems, using actual flint, tiny shavings of the steel that are removed in the striking process, rather than the actual flint, are what burn. The origin of its easy sparking is cerium's low temperature pyrophoricity, its ignition temperature occurring between 150 and 180 degrees celsius.
Since smaller scrapings become better sparks, the mechanical properties of rare earth metals must be adjusted to give a usable material; to that end, at least two strategies have been developed to make such alloys more brittle:
Oxide - most contemporary flints are hardened with 20% iron oxide and 2% magnesium oxide.
Intermetallic - in the Baron von Welsbach's original alloy, 30% iron (ferrum) was added to purified cerium, hence the name "ferro-cerium". Iron reacts with rare earth metals to form hard intermetallic compounds similar to those in neodymium magnets; such magnets are also known to generate sparks quite easily when broken.
There were actually three different Auermetalls developed: The first was just Iron and Cerium, the second also included Lanthanum to produce brighter sparks, and the third added other heavy metals.
Lighting a firelighter with ferrocerium. A modern ferrocerium firesteel product is composed mostly of iron, combined with an alloy of rare earth metals called mischmetal (containing approximately 50% cerium, 45% lanthanum, and small amounts of neodymium and praseodymium), plus a small amount of magnesium:
Iron: 19%
Cerium: 38%
Lanthanum: 22%
Neodymium: 4%
Praseodymium: 4%
Magnesium: 4%
[emphasis added]
Misch metal: An alloy consisting of about 50 percent cerium, 25 percent lanthanum, 15 percent neodymium, and 10 percent other rare-earth metals and iron. Misch metal has been produced on a relatively large scale since the early 1900s as the primary commercial form of mixed rare-earth metals. Misch metal alloyed with iron is the flint (spark-producing agent) in cigarette lighters and similar devices. Misch metal is also used as a deoxidizer in various alloys and to remove oxygen in vacuum tubes. As an alloying agent in magnesium, it contributes to high strength and creep resistance.
[emphasis added]
Got my misch metal rods from goinggear yesterday and had fun throwing sparks onto aluminum foil. Then I spent about 15 minutes throwing sparks into the bathtub with an inch of water. Those molten pieces of metal make a pop sound when they hit the water. Even my cats found it interesting and the two of them perched on the sink to watch the sparks fly down into the water. Good thing none of the sparks bounced up and into their fur.
I found that the spine of my Spyderco Calypso 3 throws very good sparks, and used in the closed position I get better leverage and control. Also nice is that its spine seems to get damaged less from striking these firesteels than the Fallkniven F1 spine does. I stopped using my F1 to strike when I noticed it got little dents in its corner from scraping the rods. The Calypso seems to resist that damage much better.
I also found the LMF striker to work well with these misch metal rods.
I'm getting anxious as I also ordered a misch metal rod from storl :D
It's the one with the compartment in the handle, so I'm looking forward to filling it up with either cotton or charcloth for those just in case moments :)
It should be here tomorrow :p
