munk said:
Cliff,
Ferguson wrote a review on 6-8-05. He measured some of the blade. Check it out.
munk
First of all let me bring it to everyone's attention that Yangdu is very much aware of what has happened and is quite upset about it.
Y'all need to write like Yangdu is reading the threads, which she does, instead of talking around her, at least that's the impression I'm getting whether intended or not and I'm sure it's not.
Here is the thread Munk is talking about.
For my .02 whatever it's worth.
Personally I don't think Bob's khuk should have deformed like that. IIRC Dan Koster had a full size GRS that did something very similar so there is precedence in this type of damage.
Also I have a WW II that UB sent me along with another khuk I had ordered, with no explanation, with the same type of deformation as well. And we all know from experience or what others have proclamied that the WW II is one helluva sturdy khuk built to take it.
Obviously the hardening process failed somewhere along the line.
So we've had a failure, so what? Except of course to Bob's great disappointment and believe me I know how that feels since my first Foxy Folly's edge failed first thing and that was with the edge convexed by me before testing.
Bad hardenings are just gonna happen now and then.:grumpy:
Mross has also brought up a good point as well. The knives used in the cutting tests at the yearly knife gathering are not overly thick knives and they don't deform, and they are most all differentially hardened as well although other techniques are used to harden them.
Hell I used to use my mom's Old Hickory butcher knife for all sorts of heavy duty wood carving chores and it never deformed and it Was THIN!!!!
With all that said Bob has done the proper thing by notifying Art. If Art can't take care of the problem then Yangdu is good for it and we all know she will make it right.
Like some of the rest of you I don't think we want to get the kamis involved because getting some thinner khukuris is really nice for a change.
Without seeing or handling one of these models I'd have to say that they are users in every sense of the word Up To A Point.
I sure wouldn't chop and then twist when the edge hit the wood because they are thin and are apt to break. I don't know but I doubt the guys testing for the ABS chop and twist with their knives, maybe Dan could tell us?
Here's my suggestion... Let's assume that they are users with limits formed with common sense as several have been tested successfully with no problems.
(This is where some extra information coming from the ones who have used them successfully would be helpful, such as....
Did you chop and twist? .... Was the wood green or seasoned? ....
Were you chopping with or against the grain? ....
Was the wood being freshly cut or had it lain for a while? ...
Anything at all whether you think it useful or not include it with what you did.)
If there are no more failures we know that they're good to go..... If there happens to be another failure or two let's examine them and send them to Art for his expert opinion and go from there.....
IMO that's the best way to proceed and this way everyone wins in the end.... Yangdu gets some very positive input into quality control.....
We find out whether the kamis can successfully make a thin khukuri or not.....
We find out if it's simply a bad hardening that happened....
And the simple fact may turn out to be that they are just too thin for hard use and should be used accordingly.
Hell maybe it was Monday morning and the kami had a hangover, hey, it happens.
It all boils down to what Uncle Bill used to say and somehow people have attributed it to me.
"When you receive a new khukuri take it out and beat the hell out of it... Beat the khukuri from every direction... Try to bend it with excessive force... Chop hardwood with it and chop it as hard as is humanly possible for you... Run a tank over it if you feel that's part of what it should hold up too... Do everything you can imagine and some things you can't."
If the khukuri fails then it's not up to HI standards. With the Katana and the Kobras Uncle Bill had to call some common sense into play. They are swords and should be treated like swords.
Maybe this mistaken run of thin Foxy Follys should be considered swords as well, we'll see.
