- Dec 13, 2005
Alrighty folks! I finally got some more time to play with the Woodsman. A lot of folks have already seen the bulk of my thoughts and experiences with this, so I hope it’s not too dull! Let me start by saying I’m really impressed with the overall fit and finish of this blade. There are many pleasant points to discuss, so let’s take ‘em one at a time.
Here’s a basic comparison pic with a billion other bushcraft knives, just for comparison. Left to right is an SWC, Skookum, MM puukko, FB Woodsman, JK Kephart, Shing, and Mora 2000.
The most striking feature of this blade out of the box is most certainly the handle. A highly contoured handle is something I’ve come to associate with a Fiddleback knife, and this was a fine example of that! Curvy like Marilyn Monroe! It really does melt into your hand and as most know that’s saying a lot from me!! Fiddleback trademark number two is of course the laminated handles! These are very attractive and give a lot of aesthetic complexity to the blade. When this is combined with too many types of pins (mosaic and plain, etc.), then it can be a little ‘much’, but this is a great interplay between richness and subtlety.
I do a lot of carving and whittling with my blades in a ‘bushcrafty’ sense, so I end up using a lot of grips. I found this handle type to be quite versatile in that regard. It was solid thumb up or down, in a chest-lever grip, and especially accommodating to a distal chopping hold. Some basic in-hand shots (forgive the quality):
Fit and finish were as high as I’ve seen from any custom blade. The laminated wood met perfectly, as did the liners. There were no gaps or glue showing. The pins met the wood evenly. The grinds met perfectly and the convex grind made for some very efficient slicing. The tip, for those interested, is right in line with the midline of the handle. Even the leather was fantastic, four damn layers (I can’t imagine what a pain in the rear it must be) with very clean stitch lines.
Of course by now I was itching to get it outside and beat it up! First, to check edge retention against cinder block chopping……….. Gotcha!!! Some firewood was the first testing ground. It’s a mix of woods, but most are oak and all are quite weathered and hardened. I grabbed a suitable baton and started splitting some wood for kindling, I was in the mood for a hot drink!
The convex grind really excelled here, there was really no problem getting through the hard stuff. The main comparison was my JK kephart and a scandi blade I had, and the extra bladelength on the Woodsman was much appreciated. I wanted to check the edge after several rounds of this, still shaving!
Chopping was just fine, though not up to my Gransfors mini hatchet that I was also playing with. It was certainly still enough to section some small limbs for shelter building, or to aid in carving. This is about thirty seconds worth of chopping, using a distal grip:
Someone else asked how the tip was at drilling. I didn’t snap a pic of this part, but I compared it to my Brian Andrews bushcrafter and my Mora 2000. Much to my surprise, the tip of the Woodsman drilled the best hole. I had thought the sharper edges of the scandi would increase efficiency. All three did just fine, but given 30 seconds each to drill, the FB had the best hole. :thumbup:
