Oh no, not with the edge!!
Thought the same thing. Any issues afterwards? And is the spine rounded?
The whole point of the exercise was to test the edge and ease of field maintenance, and to address the fact that the knife comes with a ferro rod loop, and with the supplied sheath having a ferro rod loop, to express my thoughts on this and it being a great emergency option. However to also illustrate that on a well made knife (in my personal opinion) the edge will throw sparks better than the spine. Sharply squared hardened spines are a stress riser in a user bushcraft knife. Those sharpened corners do not mix well with the various lateral stresses that are usually encountered during batonning, both from the wood being split and from the striking of the baton and the harmonic vibrations that produces. The sharp corners are a weakness in a user knife.
Ferro rods are awesome tools, and great emergency fire starters that will work under conditions where a lighter will fail you. I know this, I teach people how to effectively use them, and have written a couple of articles on the subject as well as done field R&D on a few different ferro rod fire starters. In spite of this, or perhaps because of it, I am a big proponent of match safes and storm proof matches. In my experiences, which include a panic session at an ER at the age of 17 during discussions on which of my toes should be removed and why, after dealing with long term exposure, severe frost bite, and gangrene...a good quality match safe filled with storm proof matches will allow you to start a fire quicker, even under very bad conditions and better preserve your life and limbs. I still have all ten toes, but it was close, and the nerves were severely damaged.
I tend to keep a ferro rod in my pocket that is environmentally sealed and provides its own striker, or at the least if it doesn't have a supplied dedicated striker, has a tinder compartment. This ferro rod has a capsule full of petroleum jelly soaked cotton for a handle, which will usually ignite with one small spark.
Yet since many like to carry more decorative fire starters with their knives, and because in an emergency that might be all you have....and because I really wanted to test the edge durability and ease of maintenance... I chose to use it as a standard ferro rod with organic tinder material. I was pretty impressed with how well the edge handled the number of strikes it took to ignite the tinder under such damp conditions actually. In these shots we are looking at about the first inch of edge coming from the plunge line.
These two shots were taken after wiping the blade after ignition
and these two after about five minutes of leisurely sharpening on a piece of sand paper and some clean up on a small ceramic stone. What little damage is left is barley noticeable and will clean up in a few minutes on a bench stone
But then I thought about it for a bit and thought- hey you never know what a bad situation might throw at you. What if your blade was all you had? It's good to know that the ferro doesn't do too much damage to the edge. Thanks for doing that test, I'm sure it was difficult to bring yourself to strike that ferro. Thanks man:thumbup: Well done!:thumbup:
Excellent stuff mistwalker. Truly enjoyable watching you put the Fiddle to use.
Soooooo..........when do you take on a cinder block?![]()
In the field you can also use the firesteel to hone (steel) the edge to a degree
A member of a different forum that makes custom scales and liners made some liners for his production Bushfinger. I figured I would share this pic here.
I'm thinking orange liners would look really nice on the black micarta.
