Steve, excellent post.
[phonebook]
I have done this recently, and what I found was critical was the mass of the blade. With some very heavy knives like the Busse Battle Mistress, 18" AK khukuri, HI Bowie (massive thing), I could poke them through the phonebook.
The problem here is that the phonebook was on a table so it couldn't move. I was interested in the performance for utility reasons so it was representative for that. However for a fighting knife, wouldn't it be a better test if you hung the phonebook from some rope so it was allowed to move?
I forgot to measure the amount of force I was using on the stabs, mainly becuase I was just fooling around. But it seemed to me that it was a lot (vague I know), but I think I would have knocked someone back with the kind of hits. How much force would this require anyway? 50 lbs? 100 lbs? 150 lbs?
The strike by the way, was just bicep, no shoulder, forearm raised and then extended. Details can be found in the WB review.
Edge Durability :
How much force is realistic here? Is this a full force cut? Concerning the 50% statistic, is this supposed to be regarding the area of the blade that makes the impact? I have not done this but will give it a shot if I can locate some chain - but off the top of my head any area that makes contact will not cut much of anything.
The problem is that while you can easily pound a decent knife through soft metal, if the blade encounters a lateral force while in the middle of the cut, it can take significant damage, as it does not have nearly the same bending or impact resistance as it does to compression (which is insanely high). These lateral forces will arise during strikes as the medium and the blade will be in motion.
I just checked, I don't have any chain, but how about some 1 mm thick, 1" dimeter copper pipe?
The grip tests I have done. I haven't had any body hit the blades, but have done very hard hits with them in various orientations with no problems. As for the oiling, there are few blades when oiled that I can hang on to. Unless they have either very prominent guards (Busse) or have a very aggressive grip surface (Reeves). The guards are a stop gap measure as the blade will still move around, forward and back and even rotate.
I would think that for a fighting knife I would want security over comfort. Not so low ergonomic wise that it would hinder control, but wouldn't you rather a little redness after use instead of a slip? How long is a knife fight going to last anyway? I have done chopping sessions multiple hours long so ergonomics are very critical, but isn't a fight going to be a minutes affair? I would want a very aggressive checkering.
Sing :
I think Cliff has set a "standard" of sorts.
This was never my intention. I would like to see a standard developed but I don't want to be the one that writes it. The primary goal of posting my reviews is to generate discussion, not dictate a point of view.
One general comment about fighting knives, aren't there more than one type? I have seen makers offer very slim blades as fighters that would break apart on some of the things that Steve suggested, but I think that these blades are for a very different type of combat. Certaintly not a knife vs knife type of thing, and they seems to be intended to go around things rather than through them.
Is this realistic or even sensible or should all fighting blades be able to take really heavy stresses?
-Cliff
[This message has been edited by Cliff Stamp (edited 07-09-2000).]
