Cliff Stamp
BANNED
- Oct 5, 1998
Steve, regarding impacts, it doesn't matter if your blocking speed is low, only the relative speed between your blade and whatever you are blocking. A hard swing of a chain at a blade is very similar to a hard swing of a blade at a chain (the difference will come from the fact that the chain doesn't move in a linear manner). The critical question is, would you use a fighting blade to block a full force swing from a hard object (chain or similar) and how much damage is reasonable for it to take?
While blade steels are very hard and don't compress easily, compression is determined by pressure and pressure by area. The low area of the very edge means that very high pressures will be generated from very low forces and thus even moderate impacts off of hard targets will flatten the edge until the area increases enough for the pressure to drop below the compression cut off level.
Yes, this was my point. Mass is a significant factor in phonebook stab I did and think it could lead to very misleading conclusions. There are large variations in mass between even similar sized blades because of geometry and materials. There is a simple solution which I tried yesterday. Just stab the phonebook in a horizontal plane. This seems to be more of a thrust like motion to me anyway and it removes the advantage of the mass and in fact turns it into a disadvantage and shows clearly how smaller lighter knives can have stronger penetration, precision and accuracy especially on repeated strikes.
Sing :
The point is not simply to decide on a "winner" or a "better" blade but to describe the performance variations. I would very much be interested in seeing how a small fighter and a large fighter compare. It would be informative to see for example how much precision would be lost on thrusts, what the speed decrease would be, how much cutting ability would be gained for deep strikes etc. . What do you lose going from 3/16" to 1/4", what do you gain, and how much is the difference?
Testing very dissimilar blades side by side has been a very critical process for me as it allows an undertanding of geometrical influences that would be very difficult in similar blades. It is something that is very common outside of blade work and I don't understand the reluctance to it.
The first time I went fishing with one of my uncles who was very experienced he asked me to pick out a rod. I chose a very stout salt water boat rod (because it was very big - moronic reason I know). He explained that it was not the right rod for what we were doing (freshwater trout fishing, up to 12" say) but I wanted it anyway. He let me use it and later on when I was having little success he loaned me mine and I could immediately understand the difference and why the boat rod was not a great rod for this type of fishing.
Brian, one of the main factors in handle retention is the amount of friction between your hand and the handle. This is a direct function of how much force you exert on the grip. It is quite possible that due to personal strength and toughness that handles will succeed for some and fail for others. And if you have enough grip strength (Joe Kinney) anything is secure. Like I said above though, this is not a critical problem.
As for subjective testing, as long as your baseline is described clearly everyone can understand your results. Blades are not that complicated a tool. Many tools more complicated are evaluated in a very systematic way resulting in a positive development. It is certainly my end goal to develop a manner of evaluating blades that greatly reduces the need for including a baseline as this increases the workload significantly (at least 2-3 times).
-Cliff
[This message has been edited by Cliff Stamp (edited 07-11-2000).]
You want isolate the attribute you are testing
Sing :
No point in a big bowie vs. A/F dagger.
-Cliff
