Finished mosaic handle WIP pics w/sheath finally
Mark, thank you for showing us your work! This is the type of thing you can openly show and not many people will copy. The amount of tedious work involved is incredible.
I can't wait to see the finished knives!
Very nice!
Alden
In the past I had looked at your handles and thought about what it would take to make them. Kind of like reverse engineering. I thought no way someone would cut all those tiny pieces and then reassemble them. There has to be a trick to what he is doing. I had always been impressed with your knives but now I have to look at them with even more respect. You must be a very very patient person Mark. My hat is off to you. I can't wait to see how these look completed.
I do not know if you could call Mark a saint but he is married to an Angel.
How this crusty bugger who spent fifteen years on a trap line in the bush ever got married is a mystery that will never get solved. His wife Angel has him mostly civilized but like this thread he is a work in progress.
Thanks everyone, for the kind comments, I hadt'a spend a day doing machine shop work, but now we are back. I decided to use just one of the handle blanks for the dagger project, I am going to use stacked kudu horn for the smaller one. I chose the blank that I used mahogany stain in, to go with a two piece "S" shaped mokume guard and bolster.
I cut an "S" curve forming block on the band saw and sanded it smooth.
My buddy (Bob Hook) and I have a new press in the works, (we been working on it for two years) but it's not running yet, so I gott'a do the forming in the power hammer.
Here's to two peice guard formed together, I had formed them each seperately, then put them together for one last smoosh so they nest well.
Using the same forming blocks to shape the brass and nickle-silver liners.
I am using corrigated copper liners between the brass and nickle-silver, here's the forming block for that. I made the cutters to make the blocks.
Here's how everything is stacking up.
Here's the bigger picture, More later.
Wait just a minute, I exemplify that remark:D
We want to mark everthing for orientation so we know where everything fits.
Slotting the guard, the ricosso is .150 thick, the endmill is .125, so I cut a slot in the middle, and take .010 cuts from each side, then filed the rest to fit. I am using a carbide end mill, they are stiffer than HSS, also since mokume is so grabby, I am keeping the cut lubed with WD40, all these things help prevent key-holing.
The tang shape is traced onto the handle block and the lines transfered to the ends of the block, and center lines are put on. The block is put in the vice with the drill bit lined up with one line that indicates the edge of the tang, that hole is drilled, the drill bit is aligned to drill the other side of the slot, interum holes are drilled to take out the middle and the holes are all connected.
The same thing is done on the butt end of the handle and the tapered slot is done.
The liner pieces are all slotted and the butt cap is drilled, here it is with the first dry fit. Next I will pin all the liner pieces so that they go where they are supposed to in the final assembly. More tomorrow. Thanks for watching.
OK, Got some machine shop work out of the way, put an engine back in my Bobcat and now I can get back to knife work.
I have made a dummy tang to hold the whole thing together while I do more of the work without the blade and the guard in the way, here I am using a 1/16 inch end mill to spot face the location of the drill hole for one of the pins. If I had just used a drill bit, it would have walked on the angled work piece.
I have taken out the end mill and replaced it with a 1/16 inch drill, I am drilling all the way through to 1/2 inch depth into the handle block.
Pin the first hole with a handy drill bit to hold it on location and mill and drill for the second pin, notice I have marked the guard for the ricasso of the blade, the blade will cover the pins.
Since the I don't want the pins in the butt cap to show, I drilled the holes on the butt end the same way as the guard end without the butt cap on. Then I used the last liner to transfer the location of the holes onto the butt cap, I super glued the liner to the butt cap and milled 1/16 inch into the butt cap through the holes in the liner.
So here's how the whole thing looks with the pins in, you can see the hidden holes on the inside of the butt cap.
Next I cut liner material to go between each of the other handle parts, in this case I am using bergundy suede leather. So it will be, starting at the guard; mokume, suede, mokume, suede, nickle-silver, suede, corrigated copper, suede, brass, suede, mosaic block, suede, brass, suede, corrigated copper, suede, nickle-silver, suede, mokume. I use lots of things for liner material, in this case I chose leather because it binds well to all materials, it compresses well so it almost disappears where the corrigated copper comes into contact with the liners next to it but it expands enough to pretty much fill the gaps in the corrigated copper. I really like that effect. I also chose the burgundy suede because when used with C.A. glue, the glue leaches the color out of the leather and bleeds it into the wood next to it, I like the way it looks.
Here it is with the leather liners all in, the whole thing is banded together for a dip in the C.A. glue. I want to be able to remove the guard and shape it seperately so I have only put one guard peice on (to aid in clamping and glueing the rest) and I coated it and the pins on that end with parting compound. I use grease or mink oil for that. I didn't want to plug up the tang hole with glue so I didn't pull it under vacuum, I only dipped it, the leather liners prevented glue from entering the tang hole.
Here it is after a dip in the glue, it looks like everything saturated nicely.
Here it is with the rubber bands and excess glue sanded off, the two guard pieces with liner material were put back on just to show how they go. The corrigations look filled nicely, and the liners all look pretty good. Next I will pin the two guard pieces together with the liner glued in between, and shape them. I will also start to shape the handle assembly and it will begin to look like a knife.
Please feel free to ask questions, I am not sure if I am being too detailed or, on the other hand, glossing over important stuff. I am happy to explain things the best that I can.
Are you using colored CA glue? or just the normal stuff?
I am not coloring the glue here, although sometimes I do. The C.A. glue will leach stain out of the wood and the leather liners and become colored, it helps make the whole thing blend together. I also like to use C.A. glue instead of epoxy because C.A. glue shines up real well, epoxy stays dull. Casting resin shines well but it's kind of a pain to mix and use, neither epoxy nor casting resin leach color from wood or leather so when I don't want to blend colors from part to part I choose either epoxy or casting resin.
