Oh yea lots of makers are using it. Some makers will say not to use CA glue and then many top makers ignore them and use CA glue...lol
Do you grind before or after heat-treat?
After on these long thin blades.
That's interesting. I usually throw mine in when it's cold and let it ramp. I'll try your way. I do put them spine side down on a notched out soft firebrick stand I made.
Aaron, man I just love your threads :thumbup:I feel I can trust your knowledge due to all the extensive testing you always do including sometimes very hot temps, but always very cold (sub zero) temps. All I can add is that I really appreciate all the work you put in and openly sharing and documenting all of your experiments so neatly for everybody to read. I really feel I can trust the info you provide so thanks again for your hard work brother!
Keep 'em commin!
~Paul
Hey Aaron.
I too would describe heat treated AEB-L as 'weird' and have also thought that cryo might change things.
I find my results particularly perplexing. Heat treated pre-grind, comes out of quench at 60-61 yet If i bend it with my hands, at room temperature, it will take a set. But after grinding its perfectly springy. Very fine grain in the cross section.
I look forward to testing your CA method of handle glue up. On a properly prepped joint, CA is a lot stronger than most give credit.
I use it when joining components on 'wa' handles. when the whole handle is then epoxied onto a tang its pretty much impossible to remove it without smashing the whole thing to bits.
Using it on full tangs might be an uphill battle though, customer wise.
Aaron- As always your threads are a WEALTH of information. AEB-L behaves quite differently once above 60. Although getting it above 60 is quite a challenge. Last batch I got back from Peters, Brad said he was having a hell of a time going above 61 (my goal was 62) He nailed 61 with cryo and I mainly use A2 as well and at 61 it behaves very similar to A2 at 60+. I believe they both have very similar fine grain structure.
Weird about the stringiness, when I grind AEBL after ht its a beautiful fine VERY clean dust. Almost as clean as Elmax which has been the absolute cleanest to grind to date for me.
Love the superglue idea. As always man thank you for sharing!
Interesting progress Aaron. I can't say too much about the steel since I haven't used it yet, but I'm paying attention because AEB-L and CPM154 are my choices to experiment with in the future.
I never realized you were a heavy rocker, and not a chopper, so my previous advice on the profile might not holdLooks like you're on the right track though. I'm sure you'll figure out the edge thickness and handle geometry in no time.
Aaron, as a friend and colleague I feel compelled to warn you... making kitchen blades is remarkably addictive.
