- Nov 20, 2006
I carry both, but I don't think I've ever started a fire with my lighter in the woods. Much more fun with a fire steel.
Wisdom.
I have read tens of thousands of words on how your life depends on a knife and then people go on to say that a folder is not hardcore, lifesaving gear because they bend in the middle, they have moving parts, they can fail and then you will die. And then go on to extol the value of a Bic lighter.![]()
i must do something wrong then. i carry a firesteel with my stuff, "in case". I prefer strike anywhere matches and use a lighter as backup to them. I enjoy nursing fires to life, but the firesteel is an exercise in frustration for me. It seems that it is a pain in the ass to shave off enough to start a fire. I plan to buy magnesium shavings online (I found a place you could buy them bulk) and put them in a little container to carry instead.
Red
Meh, I'm not a big fan of the firesteel hype. I have one and use it for fun, and it's great in the summer where you can just light up almost anything you pick off the ground. But when it's wet, unless you bring tinder with you, your ability of getting a fire going depends on your luck of finding tinder. A lighter OTOH will light small twigs directly.
Red
I may be a ''fire freak''. I have a small pouch dedicated to fire-starting...I have numerous methods of starting the precious spark.
1. Bic(s) One for everyday use and a couple sealed in plastic for waterproofing.
2. Ferro Rod
3. Magnesium block with built-in striker rod (I presume it's a mini Ferro Rod?)
4. Strike-Anywhere matches in a water-proof matchsafe.
5. Fresnel(sp?) lense.
6. Flint&Steel
...and I also know how to make/use a bowdrill.
LOL I guess it's better to have redundant back-ups then be without fire. I just kinda carry it to the extreme.
I realize most guys dont NEED to become proficient with a firesteel. Fact is, if you never go far, and never in bad weather, then a lighter will serve ya fine, or you can quit and go home if thats your thing too. However if you are serious about becoming a skilled woodsman, and not just in this for the gear hoarding, you NEED to become proficiant with this tool. It will help you to understand the mechanics of fire, it will prepare you for more primative means(flint and steel), and its another skil to give you piece of mind.
I know a guy, and im not mentioning names, that said "If I have a spark, I can get fire." He found out very quickly that its not as easy as some guys make it look, and it whooped his ass. Remember folks, just cause you saw it once online doesnt mean you are an expert at it, or even a novice. That only comes with practice. Light man made tinders with one in your backyard in various weather conditions, then move on to natural tinders. Practice and hone your tech to muscle memory, then practice more. When im in the bush I practice firesteel with nat materials even when I have a nice fire in front of me. Its a good feeling when you can rely on a ferro rod, and nothing else if need be. Its an even better feeling to know you can get fire proficiantly with nothing, even a knife.
Sometimes(and im not saying this is the case), people tend to use their lack of skill with a tool to put it down, or justify not carrying it. This IS an important skill, and one that is a strong foundation in firecraft.
If I need fire. Like hypothermicly need fire, Im breaking out the good ol adjustable flame crack lighter in my bag. However if said lighter is out of service, I am very confident I will have a fire with the ferro rod, even in the rain. So in that case I guess the ferro is a backup. However my confidence with the ferro only comes from the fact that my lighter is back up in every other scenerio.
I'm pretty sure that most of us (hopefully all of us!) are carrying a lighter/matches in addition to a firesteel. I don't think of the firesteel as superior to a lighter or vice versa, they are both tools that if used correctly and operating correctly can start a fire.
Jakes point that the firesteel takes practice is spot on. I concur that practicing w/ a wet or empty lighter is also prudent. The point really being, that starting a fire under less then ideal conditions shouldn't be first attempted when you most really need it.
Instead of a flare, just pack a lighter or ferro and a gallon ziplock full of wood shavings. You will get fire, and a bag of prep weighs nothing. If you need tinder for the ferro use PJ cotton. One strike to light the cotton, and add your shavings. Then squaw wood as needed to build it up. For a drying fire like that you want big flames, fast. A flare would provide ignition, but I dont see any advantages over a lighter, and a flare is a one time use item, which has no place in my kit.
I think the advantage would be ease of use. Fresh out of the ice water, a fella would be shaking so bad all dexterity would be out the window... no?
