- Feb 9, 2004
Soak a bic and a fire steel in a bucket of water for week and try to start a fire with each, that should give you a good idea of why people carry firesteels,
exactly
You guys crack me up. I hunted and fished my native Montana for years in all kinds of weather. My brother and I trapped beaver in the winter with a canoe in water that had ice on the banks in many places and often slush in the fast running water. We screwed up once and turned over in the Clarksfork river in January. Quickly went to shore and gathered a bunch of small wood. Not picky. Ripped the several wrapps of tape off the plastic snoose can in my pocket and opened it up and placed one chunk of the 2 half round piece of waxy firestarter under the pile of wood. Flipped over the sandpaper in the lid half and struck one of the waxed strike anywhere matches that I had fit between the 2 halves of firestarter and poof the fire starter was off and running and shortly the wood. We were warming in a few minutes and dry in an hour. Didn't have time to mess around with tinder and sparks and twigs and finding bark. If your going to play hard have what you need ready. A plastic snoose can with everything you need in it is very easy to carry in your pocket and it will give you immediate heat. No dicking around while hypothermia is setting in. When you are soaking wet and it is well below zero, I wonder how many of you could actually gather tinder and strike a fire or use a soaked bic. Good luck. I KNOW my method works unless I get my pants ripped plump off.
Bottom line is a firesteel takes skill and a lot better quality of tinder than either a match or a lighter. They will certainly last much longer than a lighter, but 99% of people are planning for a survival scenario lasting days or weeks, not years. And they are usually building fires in less than survival conditions. If your survival need is real and not hypothetical preparation, a firesteel backs up matches, and matches back up a lighter. Take all three and don't worry about which one is cooler to use.
One question, Blue Sky points that the firesteel rusts. Will it still spark with a coat of oil or something on it? In the tropics is an important issue!
Which types of fire-steels are any good? Saw a scout model on DLT's website, was cheaper than the army version but is it useable?
What are these vaseline soaked balls? Do you buy them or make them?
Vasoline soaked cotton balls are simply that, vasoline worked into 100% cotton balls. I place cotton balls in a plastic bag add vasoline and then knead it in. I then take a drinking straw cut it to size seal the end by holding it with pliars and melting it closed with a lighter, I stuff it full of prepared cotton balls and then seal the other end with the lighter. This makes a totally waterproof method of carrying tinder and the straw is flammable also.
Farking cold outside. Far below zero. Wet, not optimal conditions.
but isn't likely to ignite the cotton balls when you use fire to seal off the ends of the soda straws?
