- Aug 30, 2007
THIS IS A TERIFFIC POST!
I'm very interested in the rest of this info that you mentioned. Email on it's way.
I will work on a wound/fx management one, and get something up on here soon.
Exposure will follow that one. I agree that its a huge concern.
I think with knowlage of those 3 things, you would have a pretty good skillset for wilderness management.
Not to myknowlage it wont. Purpose of elevation is to help offset edema buildup. Thats an interesting question though, I am gonna look into that. I can see as maybe a long term consideration, but for first line, I think restoring osmotic balance is a bigger concern, which is priority in the first 24 hrs following a burn, as I am sure you know. Its easy to forget burn stuff isnt it? We just dont get as many burn pts to keep us sharp on skills and protical.
Not to mention the parkland formula can be a huge PITA w/o pumps. But as for our role in the TX of burns, I feel 500cc over the course of an hour is a great number, as we arent concerned with urine ouput, and central pressures yet. We are just trying to slow fluid loss, start restoring osmotic balance, and provide barrier to infection, and pain relief. Which reminds me. Never give IM pain meds to a pt. Give them IV. If you have the means to have an IV, or access to pain meds able to give IV.
Your recent course may have a different take on things but I can't agree with you entirely. All our ER and First Aid trainers emphasise that first thing to do is stop the burning and reduce further heat damage = run under cool (not icy or cold) water for at least 20min. After severe burns = major fluid loss, the victim is likely to go into shock anyway. I think the important point here is the water has to be cool and not cold and only the affected parts should be treated
I just got back from a staff meeting, where I just taught an inservice on pre-hospital management of burn patients. I was thinking I would pass on some of my lecture on to you guys.
I believe that in a survival situation, it is not to far out to believe that a burn is likely to happen. Whether you are in the desert and it comes from the sun, or are in a natural disaster and it comes from chemical or fire, or maybe even a plane crash or car crash. So you can see that it is something to consider from a survival perspective. It might be you that gets burned, or somebody in your party, or just a stranger in need.
First thing we need to look at is determining the severety(degree), and extent of burn(area). A critical burn is one to the face, hands, feet or genitalia. Or any burn that covers a good majority of the surface.
FIRST DEGREE
The least serious burns are those in which only the outer layer of skin is burned. The skin is usually red, with swelling and pain sometimes present. The outer layer of skin hasn't been burned through.
SECOND DEGREE
When the first layer of skin has been burned through and the second layer of skin (dermis) also is burned, the injury is called a second-degree burn. Blisters develop and the skin takes on an intensely reddened, splotchy appearance. Second-degree burns produce severe pain and swelling.
THIRD DEGREE
The most serious burns are painless, involve all layers of the skin and cause permanent tissue damage. Fat, muscle and even bone may be affected. Areas may be charred black or appear dry and white. Difficulty inhaling and exhaling, carbon monoxide poisoning, or other toxic effects may occur if smoke inhalation accompanies the burn.
OK. I am not gonna dive into the rule of nines, or serial halving, cause its tricky, and complicated. I will tell you that a palm is roughly 1% of th surface area. So you can use that to get a rough estimation of affected area.:thumbup: If your interested in the rule of nines, or serial halving, Email me, and I will do my best. I really dont think it has much to do wih survival type medicine, if you can recognize the severity and rough size of burn.
Now on to a list of DONTS when it comes to treatment of burns.
DONT
DONT APPLY BUTTER OR OINTMENTS, IT IMPEDES HEALING.
DONT BREAK BLISTERS.
DONT APPLY ICE, IT CAN CAUSE FROSTBITE.
DONT REMOVE BURNT CLOTHING.
DONT IMERSE IN COLD WATER, IT COULD BRING ON SHOCK.
Ok, you might be thinking, well Jake, WTF should I do then?????
Well. I think its important to look at some concerns you need to be thinking about when attacking treatment of a burned pt. The most important thing when understanding burns is avoiding hypothermia, and infection. The rate your body loses fluids makes hypothermia a real threat to your pts survival. The exposed skin makes infection a runner up in danger, and something to take in mind with long term care. We need to keep exposure to a minimum.
Serious Treatment is.....
You need to boil some water if you dont have access to sterile water. Let it cool to luke-warm, soak dressings in it, and wrap or cover affeccted area. This is where it gets kinda high-speed with a trick I lerned. Wrap saran wrap over the soaked dressing. It will provide a barrier to infection, and it will help regulate temp by decreasing the fluid loss. Cool huh?
Next elevate extremity above heart.:thumbup:
Now for minor burns,including first-degree burns and second-degree burns limited to an area no larger than 3 inches (7.5 centimeters) in diameter, take the following action:
Run cool water over site for 5 minutes. Cooling the burn reduces swelling by conducting heat away from the skin. Don't put ice on the burn.
Sterile bandage, no fluffy cotton. I would treat with wetted down dressings.:thumbup:
Pain controll is something you need to think about too if its available.
Fluid resuscitation is great if you have the means. W/O gettin into the complicated formulas for it, I will say a good number is 500cc over the course of an hour.
As always monitor for pulse, and breathing, and be ready for CPR if need be.
Now, this is only for tx of burns not related to chemical or electrical burns, which there are other things to consider. Wanna learn more????????
And I will say, that I am not a DR, nor do I work in a burn unit. Of course their treatment is more advanced with drug therpy, scrupping the burn etc, but I think this will give all of you a good idea of what to do as first line care of burns.
Sorry if I bored you, and I will be happy to post another post on chemical burns, and electrical burns if you allwant me to add it in.:thumbup:
Please do not pass on information (especially medical information that could effect someones life) if you have not checked to make sure it is true.
I have checked you dimwit. Read some of the following:
