Thank you Sheila, I'll get a hold of you after recovery.
Thanks Chris but I won't be making the sheath for this one, the knife now belongs to Paul Long (sheathmaker)
Thanks Bob
How did you texture the bolster insert and the "spine" in the handle ?
rashid11,
On the bolster texturing, I use an 1/8" round carbide burr in a flex shaft and make a random pattern applying more and less pressure to create hills and valleys.
Once It's completely covered and I'm happy with the pattern I use a small wire wheel in the flex shaft to blend everything, soften the edges of the hills and smooth out the tooling marks from the valley's, finish with a light oil rubbing of 4/0 steel wool and gun oil.
Not sure I know what you mean about the spine of the handle but here's what I did. The handle is made up of 5 pieces, the checkering file lined (20 lpi) copper center piece is sandwiched between 2 bronze pieces topped with 2 black G-10 pieces then the entire assembly is blind pinned (6 pins) to the stag scales. The handle is secured to the blade with a pin through the tang then epoxied, I added another checkered copper pin and thong tube.
Hope that all made sense, if it didn't please let me know
Thanks Tai
Steven, dlpierson, I was hoping another maker may like to see the insides, thanks!
Dave
