- Jul 5, 2006
how much would it cost to have an exact replica of th knife made,by a custom knife maker with more durable materials
The originals sold from Lile for about $600-$800 and were made from D2 steel.
Now that Lile is gone and many years has gone by, expect to pay anywhere from $1000 -$1500 for the first blood knife and around $5000 for the knife from the second movie.
Les Robertson gets them once in a while, but if he gets it for you, you're going to pay for it.
I onced owned this very knife. While the steel is excellent quality I would not bet my life on the knife or any other knife that has the same hollow survival handle. Remember with the handle being hollow there is not full tang. If you don't know the tang is the metal part of the blade that extends into the handle. Without a full tang you only have a small stub of metal going into the handle that will break easily.
Ummm...I hate to put a damper on your tirade on the inadequacies of the "short tang survival knife", but almost any knife can snap at the tang...regardless of it`s length. The solution to this problem is a proper heat treat. Apparently, the Buckmasters suffered from this dillemma when they first came out back in the mid 80s, and Buck swears up and down that they corrected the problem shortly after. Now if you are referring to a loose blade/loose handle type scenario...well, I think it is safe to say that any knife with a full tang is just as prone to experience a loose handle. I really don`t think it is necessary to cite examples.
From the info that I`ve gathered, a quality hollow-handled knife with a piece of pipe for a grip (with the exception of the Chris Reeve line) will have a threaded tang that is epoxied in place and/or a metal dowel inserted orthogonal to the grip. The result is an exceptionally strong attachment between tang and handle...assuming that it was done correctly.
Curiosity yields evolution...satiety yields extinction.
The rambo knives are some great looking knives.I would not bet my life on the knife or any other knife that has the same hollow survival handle. .
Because this is a forum I am going to disagree with you. (I can do that can't I?)
Anyway the hollow handled survival knife only has a short piece of blade protruding into the handle. Usually no wider than 1/2" by whatever the thickness of the blade is. While a full tang blade has the strenght of the entire width of the blade running the full length of the handle. Even if the handles do happen to come loose at least I still have the full functionality of the blade at my disposal. In a pinch I can wrap the handle area with anything and still be able to use it. The Hollow handled is going to be useless when it comes loose from the handle. All I'll have is the blade to hold. There won't be anything else to grab onto.
IMHO....The hollow handled knife has created it's own weak spot when they joined the two metals at the point it is most likely to suffer the most pressure from.
Do you plan on using it? If so, avoid United Cutlery like the plauge!![]()
