Sorry, I missed your location. A dime is 1.35mm thick. Since you are in Denmark, the analogy isn't really applicable ,anyway. A 50 0re or 1 krone is about 1.55mm , so it is a bit thicker than a dime. You are looking for about half to one fourth the thickness of a 50 ore.
My comment was mainly to correct the old, " The edge should be as thick as a dime" post. In the old days of carbon steel knives and with less HT control, 1mm or so was a good rule of thumb. Today, around half the thickness of a dime ( .5mm to .7mm) is the norm on carbon steel.
Stainless steel edges are usually about 1/4 the thickness of a dime ( about .3mm to .4mm) at HT.
Your blade will be 4mm (.15") thick at the spine. If worried about warp, the edge before HT should be at the most .75mm (.030"). A full flat grind (FFG) would be the best choice for such thick stock.
Your current edge of 1mm ( .040") at HT is OK, but you will have much more grinding to do post HT to thin the blade down.
