That's how I carry mine. No problems.I think an M&P9 Pro would be easy enough to conceal IWB.
Thanks harkamus! I failed to think of having the magazine separated.Handgun unloaded and magazine separated out of immediate reach is what I've been told. Personally, I just put all my stuff in a range bag and put that in the trunk.
1911s in general can be finicky, that goes double for a 9mm 1911. I'd stay away from this one, especially for your first gun.
The .45 1911's felt very good in hand, so I figured the RIA 1911 would be worth looking into. I wouldn't have even given it thought until I read your earlier post (#30 in this thread) and it piqued interest. However, I take these responses to be that I should not depend on this model for self-defense (or those on the lower end of the spectrum) correct? Still like to own one someday but for this I think it will be one to save up for.Stay clear from a 9mm 1911 unless you want a "fun gun" that you don't want to have to depend on. If you want one that works, be prepared to spend many times what you'd pay for a Glock or M&P. The only 9mm 1911 styled gun that gets lots of endorsement is the Spec Ops 9 from Wilson Combat, which will set you back 1800.
As I said before, I'd recommend starting at 9mm instead of .22. The .22 is such a tame beast with almost no recoil that going to a 9mm will be an eye opener for you. Basically a .22 will let you learn gun handling without the recoil, something you can do on 9mm as well if you commit the time to practice dry firing.
I hope this illustrates the importance of practicing a trigger pull when you're not on the range shooting live rounds. It goes without saying that one of the first things you should buy after you buy a handgun, besides a set of cleaning supplies, is a couple of snap caps.
Definitely, will do.Glad to hear you had a good time at the show.Go see Brian and he'll show you the pros and cons of each model.
Spring fatigue is not something that I had thought of. Is this a common problem?I have a .357 revolver for my house gun (don't have to worry about spring fatigue leaving it loaded for a long period of time). I know, some will argue this point...
How do you tell what kind of ammo will be high pressure or low pressure? And how do you determine what type of ammo to use (is this part a bit of trial and error to see what shoots well with the pistol)?Do not be recoil shy, it is a misconception that .45 kicks more then 9mm all the time. My 9mm Beretta M9 recoils harder and snappier then any of my full size 1911's.
.45 is large caliber LOW PRESSURE round,... 9mm, 10mm, .40cal....HIGH PRESSURE rounds. High pressure round in a light, compact, polymer framed gun, will generate quite a bit of recoil. Just something to think of.
cool neighbor) have told them. Do not listen to them or me, do your research about ammo, and find yourself gun that fit you.
When I mentioned 1911s I was just trying to get you to realize that there are some full size handguns that you can conceal if need be, the 1911 being one of them if you have a decent holster. 1911s were built on the .45 acp as the bullet of choice, which is why 9mm versions often have issues with them. That doesn't mean good ones don't exist. They are just a lot more rare and usually cost a good bit. There are plenty lower priced .45 1911s, like the RIA for example, that are great for self defense. Still, it all depends on how proficient you are with the weapon, whether that's a 1911 or otherwise. Also factor in ammo costs. I'm assuming you will not reload, so .45 will be damn expensive. 9mm will be considerably cheaper, which means you will end up shooting it more at the range.
Some snap caps wear out after a few hundred dry fires. Others last thousands and thousands of dry fires. Get the A-zoom. They are aluminum with a hard plastic in the back that the firing pin hits. These will last a loooooooooong time. You get 5 per pack for around 15 - 18 bucks. Yes, they prevent damage to the firing pin.
How does one tell if ammo will be high pressure or not? Well, there are two parts to this question. 1) 9mm generates around 35,000 PSI around the barrel walls when it shoots down the barrel. This is considered "higher" pressure than .45. .45 will generate around 21,000 PSI on the barrel walls as it shoots down the barrel. 9mm rounds are almost always over 1000 FPS muzzle velocity with 115 grain loads being closer to around 1150 FPS at the muzzle. .45 will almost always be below 1000 FPS with 230 grain loads being closer to around 750 - 850 FPS at the muzzle.
2) A round can be high pressure relative to it's normal operating pressure. This is designated by +P or +P+ after the caliber name. For example, 9mm +P or or .45 +P+. The name is stamped on the case head with the exception of NATO rounds. This is standard nomenclature in the US under SAAMI pressure specs. Overseas it's different IIRC since they go by a different PSI reading, from a different part of the bullet. A higher pressure load is just that, a bullet that exerts more pressure on the barrel walls. More pressure = higher velocity and consequently more wear and tear on gun parts. Many guns are not designed for +P bullets, though they probably can fire a few rounds every now and then. The exception is HK, which specifically tests their weapons with repeated bouts of +P ammo. 9mm +P is loaded to around 38,500 PSI. The .45 +P is around 23,000 PSI.
+P+ has little regulation since there is no ceiling (no cut off) to my knowledge, whereas +P loads have a maximum operating pressure, that is they can be "up to" 38,500 PSI for 9mm +P for example.
The reason +P and +P+ exist are because faster velocity = more energy on impact. Also, you can use a heavier bullet and get the same velocity in +P that you would get out of a lower weight bullet in non +P variety. Also, it goes without saying that most +P or +P+ loads will generate more recoil.
Now if you reload, it's a different game. I can make a softer feeling (less recoil) round that goes faster than factory ammo. It depends on what powder you use.
NOTE: I was only using 9mm and .45 as an example. There are +P versions of most calibers but 9 and 45 are what I'm familiar with.
EDIT: Spring fatigue is not something you should be too concerned with. It's not like spring fatigue happens often at all. Train with your weapon. Replace springs around 5 - 10,000 rounds depending on what the manufacturer says. Most guns can go past that round count, but the manufacturers like for the customers to play it safe. Regarding magazine spring fatigue, just cycle your magazines by rotating which magazine stays loaded.
Revolver for first gun, I'd say a heck no to that. Learning a long trigger pull on a DA revolver is not the easiest thing to master for a person new to shooting. Sure, you pull the trigger and the thing goes bang most of the time. A Glock or M&P do too and have a better trigger pull.
EDIT 2: Whatever you do, steer clear of aluminum and steel cased ammo. Brass has a higher modulus (tendency for a material to deform) than steel. Whereas brass will just swell up a little, steel could expand and crack which can cause damage to a firearm. Most manuals will say not to use steel cased ammo.
Also, don't shoot lead bullets if your gun has polygonal rifling. That's a rule of thumb. Some people do shoot lead bullets through polygonals but those people usually reload and use lead bullets that are harder so the fouling is minimized in the rifling. If your gun has land and groove rifling, by all means shoot lead.
YAY for information overload!
