Handle seems a little thin, but certainly a nice job on your first knife, make sure to post pics as it progressesNice.
Thickness? Blade height?
The tang's height seems short. Would someone with larger hands find its grip lacking?
Thanks guys! Really appreciate your feedback.
3/16" a2 steel. Blade is 1.5" tall, the tang was meant to be about an 1/8" or a little more wide, but I messed up haha. The next one will be wider. BUT it's still quite comfortable to hold and with some scales I think it'll be ok for numero uno. I would say at the thinnest the tang is just shy of an inch wide without a ruler.
Yea I had a hard time getting the grit marks out of the blade's center, so I guess hand sanding is the only way to do it without risking messing up my grind? What's the grit progression you'd use to get the marks out?
Anything else I should do before sending it off for HT?
Again, thanks for yalls feedback! And I'll definitely post some progress pics when I move forward.
Overall it's a nice design. Like stated, thick scales & it should feel good in hand. I would buy one to give it a go. Look forward to seeing your progression.
It looks like the top line of your grind does not properly follow the curve of the blade edge leaving the tip too thick. Otherwise, great first blade!
-Peter
...What's the grit progression you'd use to get the marks out?...
