I don't know what size you're looking at, but 4 oz. of T-88 shouldn't be much more than $15 iirc and goes a looong way.
I use west systems g-flex, both to attach scales and dab the holes/smear the pin as I push it in. Let everything cure properly then nip the pins flush with either an angle grinder or cable cutter, the rest is back to the belt and sandpaper.
Ok yea... I guess i should of said its expensive compared to JB Weld or loctite![]()
Not that 15 bucks is a WHOLE LOT of money... But 15 bucks here 20 bucks there 17 bucks over there.. ETC. Adds up real quick.
But if this is whats needed ill make it happen!!
Ill probably use a hacksaw to cut the pins close to size and then file them down.. Thats the plan anyways.
Lookin' good, WW. You've got me inspired - I'm going to see about getting some steel next week.
