Firtst impressions: Opinel #7
Recently got a few Opinels #7's from ragweed forge, as usual Customer surface was outstanding and 2 days after placing my order I had the knives in hand. At first glance the Opinel #7 can be described as a utilitarian design with a certain cultural elegance to it..it has a pear wood handle a slightly up swept "skinner style blade" made of carbon steel, and a unique twisting ring locking mechanism..I have owned Opinels in the past but have usually passed them along as trade items or gifts..But decided I'd get A few to put through the paces as actual users. The #7 is what I would describe as a medium style folding knife..with a blade that is slightly over 3 inches in length..it has a cylindrical handle that is rather comfortable to hold, And the blade stock it self is very thin...Out of the box, Both knives where very dull, but Instead of taking it to the sandpaper or the stone I decided to see what a loaded strop would do..Within less than a minute the first knife was easily shaving hair slicing paper and push cutting through newsprint..I attribute this to the relatively soft steel and thin blade stock. I pocketed it and decide to bring it to work with me..As part of my additional work responsabilites I was required to dispose of a large industrial cardboad box..4x10 feet, and about 3/16's thick..I was reluctant to use the extremely light. thin and fragile feeling opinel for this but since it was the only knife I had on me I decided to give it a whirl..At first I tried to just push the cutting edge through as I have done int the past with thicker knives and, found that not to be very effective. However once I began to use a long sweeping slicing motion the humble blade sheared through the cardboard like nothing..After a lot of cutting the project was complete..the blade was still sharp and would catch a finger nail but..was definitely not shaving sharp. However a few strops on the cardboard I just cut and it was back again. I have noticed some tiny little blemishes (1 or 2) that I havn't removed yet..I think much like a mora one might have to remove a little steel to get to the "good steel" Which might hold an edge a bit longer...THis morning I made some fuzz sticks (a breeze with such a thin blade, and carved a figure 4 trigger out of maple..A little contact with some Hard wood carving and you might have to hit a strop again..I wil be carrying this knife as part of my normal battery and will be subjecting it to more wilderness related tasks as I go and when done will conduct a thorough review Hopefully with pics..But the My first impressions over all are Positive:
I found a cheap knife with a sort of classic look and feel that while relatively easy to dull, is wickedly easy to sharpen with nothing other than cardboard or a belt. WHile the thin profile allows it to do well for carving and shaving wood I feel this knife is much more of a slicer..and it seems it would be great for game prep, Skinning, and it is thin and flexible enough that I think it might even make a servicable fillet knife in a pinch. THe locking mechanism when engaged is quite secure and almost fool proof provided you are using it within it's means, THere is litteraly no lateral of forward to back blade play when the lock is engaged, and there are no springs to break over time. Also the thin squared carbon steel spine of the blade throws an enormous amount of sparks off a ferro rod, and the knife is so light that when thrown into a pocket, you almost forget it's there. Overall for a folding knife that can be had for between 7-9 bucks it's really hard to go wrong..I'll post my findings after I really get a chance to take it outdoors,,Thanks for reading.
I really like the #7's, trouble is I can't keep them. :eek:
I keep putting one in my Max M-2, take it out to perform some task........
someone says 'wow, that's a really cool knife'.....
.......... ah, ok, here, it's yours :thumbup:
Glad they're inexpensive !
Thanks for the review, I have been thinking of getting a couple to try out. +1 for Ragweed Forge, great customer service and super fast shipping!:thumbup:
Nice review. It would help if you broke up the wall of words though.
I look forward to the next one with pics!
Stingray, I have keyboard issues that make that difficult..I'm getting a new one,,because this as my last 2 where subjected to a 2year old who takes any liquid bearing container, and spills out while saying "Waterfall"
riley,
good to hear you like the #7...
i got a coglan's version, with the hump on the back of the handle rounded out...not really necessary but cuts down a tiny bit on the bulk in pocket if that's an issue.
i love opinels for their low price, thin carbon blades that are easy to sharpen, nice convex grind, foolproof locking mechanism and the really hand-filling grip. my main issue with them is the swelling of the wood during the summer...its what prompted me to start carrying my buck stockman.
but, with an hour or so with some basic tools that can be solved, and i plan on doing it to my next one.
also, like you said, i think the steel gets a bit better a little farther back, i ground off the edge and put a fresh one on when i got my #10 (since traded away)
The #7 was one of my first knives as a boy. I love opinels, but havent owned one in a long time. Id like to get one, and make my own handle for it, out of some ancient walnut I have, or maybe some osage.
hey Riley,
Take some sand paper and some Helmsman Spar Urathane and give the wood a nice waterproof finish. Easpecially inside and around the pivot. It won't swell so easy if it gets wet. I've got it to where it will take a 10 minute submergence in a glass of water with only minor stiffening of the joint. :thumbup:
Cool thanks for the tips guys...If it pans out ok for the next few months...I might try to send it out to have an antler handle put on it...I saw a cat who does that on the net over at bearclaws bushcraft.com Looked awesome, and will solve the swelling problem all together.
LOL, that is hilarious, it sucks, but it's hilarious.
Hey do you have a link to that antler handled Opinel you mentioned?
Wow, those are awesome firesteels. I would love one to pair up with my ML. Those opinels look great too! Great link RR.
i have a few opinels which i use alot. i have a #6 and a #12. i have battoned through pecan, both with and against the grain, with the #12 several times and there is no damage aside from a few blade scartches. mine are both in carbon. nice reiew too.
Gotta love the #7. It's my number one knife for simple food preparation when I'm out and about either in the city or in the woods. Great knife for slicing cheese and summer sausage and fruit.
A neat tip about using it to scrape a fire steel. . . You don't have to open it. That way you don't have a sharp edge to worry about while you're getting your fire gong, and as unlikely as it is that the blade might close when using it the other way, it's a complete non-issue if you just keep the knife closed in the first place. You do tend to get some black marks on the handle of the knife that way, but they mostly just wipe right off.
Those pimped out Opinels with the horn and antler handles are pretty sweet. I'll have to try my hand at modifying one or two one of these days, but I'm sure mine won't turn out nearly as nice as those.
Yeah I am really digging it so far..The blade is a little large for detailed whittling..For bushcraft style whittling it seems fine but I''m making a little figurine at the momentand find myself wanting something smaller...My 1 concern right now is the longevity of the knife it just feels so light and thin..Yet I cant see there being many ways for it to break, Aside from the blade snapping. I mean even if the lock breaks the blade stays open just fine under tension..Once I get some brush time with it I'll be able to give a better review.
salamander, thanks for reminding me.
it is nice to be able to use the knife for a scraper smoothing wood things like spoons, walking sticks, etc. also good for making really fine fuzz off of a dry stick for starting a fire. and like you said, no danger of an edge like using a square-spine fixed blade.
EDITED to add,
instead of adding another post 2 seconds later i am just editing,,
i like that the carbon on the opinels almost seems semi-stainless...vs CV it takes a lot longer for it to patina. when i cut up an apple with my first Case in CV it immediately clouded up nice and pretty...the opinel took three or four apples for me to see any difference.
The opinel #7 is my urban EDC. I just love this knife. Very people friendly, easy to sand the handle and custom fit your hand. It is one of the best slicing knives for simple food prep, like peeling an apple, cutting grapefruit etc. that I've ever used.
The swelling is a bit of a problem and one of the reasons I don't really take it on camping trips. I've had it swell so bad that I needed to pull out the blade with my leatherman pliars.
I haven't a problem with the handle swelling yet..It's been pretty humid here as well and Ilive on a coastal city.. I might have to drop it in the drink and see what happens.
They are wonderful knives at a wonderful price!
I used mine to try the mustard/gun blue patina. It worked well.
I took it on an eight-day bicycle trip last week that included a few days of riding in heavy rain. The Opinel was in a small dry bag with some other things and a little water got in as I accessed items in the bag a few times, making things damp. The only rusting occurred on the bevel; just a half-dozen or so very tiny spots. They must be fairly deep though, as they didn't come off after running the blade across the leather belt on my belt sander.
Mine suffers from the wood swelling and is difficult to open in these humid summer days. I tried spraying the joint with some Breakfree CLP but that made matters worse. I then used a large flat-blade screwdriver to pry open the metal "collar" around the pivot. That helped a lot.
I intend to buy a pile of these to give as Christmas gifts this year.
Stay sharp,
desmobob
