Threethreethree, I see your point. At one point,I wasn't sure what I wanted and have gone throught the same routine as most new knife collectors. After a while, I realised what worked for me and what didn't since I will use and some times abuse my knives. I have broken smaller pivot screws loading the blade all wrong. I have busted the tips of some knives using them as a screwdriver or even a prybar up to 1/2" of the blade. After a few years of experience with what was hot and what was spit on. I ended up with Emersons as my primary brand. 0 failures for me. Linerlock vs Frame lock... Both work fine. The only people that have issues with these form of locking mechanism are ones that think their knives are for designed for spine whacking and battoning. It's a knife, to be used along the sharp side of the blade as intended. Personaly am not a huge fan of framelocks for work due to the fact that I will twist on the handle to make circular cuts through thick cardboard, sheets of plastic and hard rubber. I also fully appreciate the ease of disassembling a Emerson compared to others that I can't even take apart or have some mechanism comprised of a small pieces that I don't like. I am fond of simple things that work. I am also not a fan of slim profile knives, feel like holding a ruler in my hand instead of a knife. I am also a fulltime bicycle mechanic so my work knives will get grease, various oils ( brake, cable, chain and others), solvents and grime on them so a through cleaning will be needed. Blade metal... I was mostly using S30V at one point, wasn't sharpening less often compared to what others have said with their supersteel jargen and spitting on 154CM. Edge strength didn't seem all that different to me for how I use my knives. " I NEED THE LATEST SUPERSTEEL OR I AM SUCH A LOSER" mentality also needs to stop since most users won't even come close to hard usage.
The hype... It is what it is. Mr Emerson has a huge martial arts background so I can't blame the guy for doing what he does and does it well. I would probably do the same. We aren't a bunch of kids so there is no need for all this negativity. Any sensible mature individual will look at a product for what it is, not what someone says unless your a teenager that thinks the Teenage Mutant Ninja Turtles are real.
Don't like it, move on. Buy what you like, not what people tell you to. Pricewise, shop around. Deals are out there and most of mine are purchased NEW in the similar price range as other brands I have considered when I was looking. I buy Emerson knives because I know they work for me better than most and it is a preference from real use as a tool, not a pocket accessory or weapon.
